Old 11-07-2018, 12:56 PM   #1
timbstir
Drives: 2010 Yaris Seden
Engine Block Coolant Drain Cock Location
Sorry for the stupid question. But where is the Engine Block Coolant Drain Cock located on a 2010 1nz-fe, found a "diagram" online that showed it just about the intake manifold, but the bolts or plugs around there are the intake manifold bolts.
timbstir is offline   Reply With Quote
Old 11-07-2018, 01:08 PM   #2
tmontague
tmontague's Avatar
What you were looking at in the diagram wasnt the intake manifold, it was the exhaust manifold.
It's on the back of the block under the exhaust manifold.
FWIW you only end up removing an extra 100mls or so when you use the block drain valve compared 5o the radiator pet cock
Old 11-07-2018, 10:25 PM   #3
SirDigby
Drives: 2007 yaris 3 door
this is true. it's not really a "drain." more of a "bleeder" for when you are filling the system. air can become trapped it that area and it's good practice to crack it open when filling... (of course close it when coolant flows out)
also, what does "FWIW" mean?
Old 11-07-2018, 11:11 PM   #4
tmontague
tmontague's Avatar
"For what its worth"
There is no way I'm reaching near that exhaust manifold while the car is running to bleed the coolant
The 1nz bleeds very very well by itself within the first week of driving it. Keep the overflow reservoir topped up and your good to go
Old 11-08-2018, 03:42 AM   #5
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
"For what its worth
Hey that belongs in this thread:
http://www.yarisworld.com/forums/showthread.php?t=61233
Does anyone get the reference?
DIY: Engine Grille Block BailOut DIY / Maintenance / Service 39 11-11-2017 10:33 PM
The Nitrous Thread ChinoCharles Performance Modifications 116 02-16-2016 04:07 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
engine block heater linny DIY / Maintenance / Service 6 01-19-2012 12:22 PM
Engine Coolant Temperature djino General Yaris / Vitz Discussion 18 07-16-2007 01:26 AM
