![]() Drives: Yaris 4dr 2008 Join Date: Nov 2008
Cold engine light randomly comes on while warm.
Am I the only one who gets the cold light to come on while driving ??
When I mean driving, I mean on the highway for 30 minutes. I have searched the forum for this and it does not seem to be a common problem. The heater is blowing hot air at will, the coolant level is right on, I figured that maybe the ECT sensor is faulty, but the ECM throws no codes and should, unless there was air or steam pockets in the coolant stream or the engine temp dipped under 130 F ?? Unlikely I say, but any input on this will be appreciated. Anyone knows the resistance of the ECT @ X temp in ohms ? |
![]() Drives: yaris sedan Join Date: Feb 2009
my same problem i have a toyota yaris 1.3 engine 2nz-fe with 150000 miles but this appears only in winter or cold weather please help me
Could be a faulty water temp sensor. Even when my car goes back below 129 degrees F the sensor doesnt kick back on, so once it's off it should stay off even if the cars cools down due to running the heat.
Use a scanner to read coolant temp and see if your sensor is shot
Yeah, could have a t-stat that won't close all the way. Best way is to scan it. Let the car idle till it gets to 180 or 190. Drive it, the temp shouldn't fall below 170 or so.
i have changed the ect sensor and the thermostat the problem is persisting and i have scanned the memory no error codes it is very strange realy i I think it's the maf that gives false data on the air temperature , not sure
| Differntial diagnosis for the check engine light yaris sedan | dante2086 | DIY / Maintenance / Service | 1 | 12-18-2010 09:04 AM |
| Engine management light for 300 miles then off for 300 - this cycle keeps repeating | stripey | DIY / Maintenance / Service | 0 | 08-01-2010 05:43 PM |
| Yaris Squealing Sound | Yaris | General Yaris / Vitz Discussion | 19 | 01-18-2010 10:58 PM |
| Cold Engine and Gear Shifting | captainm27 | General Yaris / Vitz Discussion | 9 | 01-29-2009 08:27 AM |
| service engine light @ 9000 mi? | dandj | DIY / Maintenance / Service | 21 | 01-03-2007 12:30 AM |
