Old 11-01-2018, 04:32 AM   #1
NorthernGirl
NorthernGirl's Avatar
Drives: Toyota Yaris 2009 1.5 hatch
Radiator Cap - 1.1 bar or 0.9?
Hello everyone,
I own a 2009 Yaris LE 1,5L hatchback. She was in a accident recently - long story short, everything is fine by now and she runs like nothing happened
But a radiator cap is scratched, so I decide to change it. The thing is, the current one is 0.9 bar. I ordered a OEM new one (and received it already). The seller put in my order a 1.1 cap, instead of 0.9 I chose. They insist the 1.1 cap is the right one, not 0.9
I googled and yes - the most results confirm what the seller said.
But:
- I'm a second owner, bought my car 2 years ago. Right before selling, previous owners did a full inspection at the dealer. There are bunch of recommendations in those inspection's papers - but nothing about radiator cap or cooling system whatsoever.
The dealer just overlooked the "wrong" radiator cap?..
- I've never had any issues with the cooling system since I bought my Yaris. No overheating, nothing is leaking, the ODB shows "all the sensors report no trouble codes", etc. All these 2 years with the 0.9 bar radiator cap
But now I'm confused - which on is the right one? 1.1 or 0.9?
Thanks in advance!
Insta
___________________
http://www.yarisworld.com/forums/image.php?type=sigpic&userid=64242&dateline=154103  7092
NorthernGirl is offline   Reply With Quote
Old 11-01-2018, 03:25 PM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Good question.
The GSIC manual says a new cap should test as 0.95 to 1.25 while For a used cap, the minimum acceptable reading is 0.8
This suggests to me that the 1.1 cap is more likely to be the correctone, but the 0.9 cap would be an acceptable substitute.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 11-01-2018, 03:34 PM   #3
tmontague
tmontague's Avatar
Either would be fine. The dealer never mentioned it as it is well within spec for them. I also doubt they go to the lengths of testing a rad cap for an inspection.
You're over thinking it, either will work and you will not notice a difference for a daily driver.
Old 11-03-2018, 06:01 PM   #4
SirDigby
Drives: 2007 yaris 3 door
1.1 is fine. all it is for is protection of the cooling system. if you are overheating, it will not matter which one you have.
Old 11-03-2018, 07:44 PM   #5
DarkShadowFox
i use the TRD uprated one.
Old 11-15-2018, 06:14 PM   #6
NorthernGirl
kevinj93, that's a very interesting information, thank you. May I ask where did you get the GSIC manual?
tmontague, probably you're right about overthinking, but as long as I learn something new - I'm fine with it :-)
Thank you everyone for your help and comments, much appreciated.
Insta
___________________
Old 11-15-2018, 06:45 PM   #7
bentjazz
Drives: 2009 Yaris--3dr MT
Love the profile pics, NorthernGirl.
bentjazz is offline   Reply With Quote
Old 11-15-2018, 06:45 PM   #8
DarkShadowFox
always go with the higher pressure cap, why risk boilover?
Old 11-16-2018, 02:18 AM   #9
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
GSIC
DarkShadowFox originally posted a link to download the GSIC.
A quick check shows he has since deleted it. It's about a 100MB zip file. I have uploaded it to my Google Drive. You can download it here:
https://drive.google.com/file/d/1-fp...ew?usp=sharing
Old 11-19-2018, 08:24 PM   #10
NorthernGirl
DarkShadowFox, it's not about going higher or lower - it's about finding the right one. From what I know, it's better to use what is supposed to be used, which is why I was wondering.
bentjazz, thank you! She loves to travel
kevinj93, downloaded, thank you very much!
Insta
___________________
Old 11-20-2018, 01:09 PM   #11
DarkShadowFox
been using the TRD cap for about a year now.
Old 12-29-2018, 09:27 AM   #12
ojeysky
Drives: Sedan Yaris 2010
Should I be worried
I noticed the small round rubber that is normally attached to the rad cap is no longer there. I don't know where it fell off to but I wonder if it fell into the radiator. I already changed the cap but should I be worried of any possible damage to my cooling system?
ojeysky is offline   Reply With Quote
DIY: Rear shock, sway bar, and strut brace refit Tapokata DIY / Maintenance / Service 19 05-31-2016 02:05 AM
xA or xD front sway bar fit in to 07 Yaris yariseggvvti Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 10-29-2012 10:47 PM
Ultra Racing 23mm Rear Stabilizer Bar Loren Performance Modifications 62 05-18-2009 08:20 PM
C-Pillar Bar Installation Guide AlainMikli Wheels, Tires and Suspension Forum sponsored by The Tire Rack 13 05-08-2009 10:29 AM
solid torsion bar bushings... the best rear anti roll upgrade turboyaris Wheels, Tires and Suspension Forum sponsored by The Tire Rack 28 12-06-2008 12:37 AM
