Old 01-19-2019, 03:12 PM   #1
HDTechVideo
Drives: Yaris MK3 1.33L Dual VVT-i CVT
Starting issue
It is taking couple of seconds to start the car, but after running few miles it start instantly. What is causing it? any idea?
HDTechVideo is offline   Reply With Quote
Old 01-19-2019, 05:37 PM   #2
Battery could be getting low. How old is it? Have you ever let it completely die before?
Old 01-21-2019, 10:52 PM   #3
HDTechVideo
2013 model. Yes once it happened.
Sent from my SM-G935F using Tapatalk
Old 01-23-2019, 10:59 AM   #4
logoris
Drives: 2017 Yaris SE Blue Streak
I have been having trouble as well,
what I have figured out is the batteries are quite small
seeing as I live in the great white north, I notice it chugs when it gets below -10c
when it was -21c it only had 1 or 2 cranks left before it wouldnt start.
My commute is long enough that the battery will charge, but if it sits for a couple days or it gets cold then the battery struggles
mine is a 2017 yaris 5dr se auto
anyone know if there is a larger battery that will fit?
logoris is offline   Reply With Quote
Old 01-29-2019, 08:50 PM   #5
HDTechVideo
Solved. Battery replaced.
Tags
starting, yaris
2007 yards starting issue Grant31781 DIY / Maintenance / Service 6 12-19-2016 09:45 AM
Weird starting issue shepd DIY / Maintenance / Service 7 03-23-2016 12:20 AM
Vitz starting issue Xuhaib DIY / Maintenance / Service 1 10-25-2013 07:13 AM
Starting issue tyrone_yaris General Yaris / Vitz Discussion 4 03-27-2012 01:16 AM
2009 Yaris starting issue -need help cudchew DIY / Maintenance / Service 15 12-16-2011 03:24 AM
