Old 01-15-2017, 03:29 PM   #1
fourbangingfun
fourbangingfun's Avatar
Current State of Rust: 10 years above the salt belt
The other day I posted pictures of my rotted control arm bolts (posted in the control arm bolt megathread).
So, today I took a few pictures of rusty spots within the engine bay. I wanted to share with you guys to see if this is normal, or worse than normal, and what types of preventative measures should be taken.
Are these findings normal? What about you guys in Canada? My plan is to drive this vehicle until it fails. Where should I be looking for rust under the vehicle? Control arms/frame/suspension parts??
FYI the vehicle is a 2007 Yaris Sedan, with 183k miles on it. Spent its whole life in Massachusetts, driven year round.
Here is a general shot of the engine bay.
Here are two shots of the passenger side shock tower. I noted rust beginning there about a year or two ago, so I sprayed the area with some PB blaster and coated it with oil, in an attempt to stop the spread of rust/rot.
Here is the driver's side shock tower. Not treated at all. When I saw the passenger side beginning with rust a few years ago, this side had no issues.
Here is a shot of the battery and its brackets.
And lastly I took some pictures of the clutch bleeder valve/starter area in front of the engine bay. My starter was replaced a couple of months back (as you can see it stands out, completely free of rust). The bleeder valve is significantly rusted. I used it to bleed the clutch last summer, but I'm afraid if i were to try that now, I might snap it off.
fourbangingfun is offline   Reply With Quote
Blitz Supercharger Belt Slip @ Higher RPM? Freestylin Forced Induction Forum 20 09-06-2017 08:32 AM
Rust Inhibition - What do you all do? tmontague DIY / Maintenance / Service 9 03-05-2016 02:02 AM
yaris timing belt phenoyz General Yaris / Vitz Discussion 16 02-24-2015 02:05 AM
DIY how to change you belt in 10 minutes without breaking VVTI solenoid YarisSedan DIY / Maintenance / Service 2 04-12-2013 11:41 AM
