Old 06-05-2025, 09:19 AM   #1
Or05230
Drives: 2007 Yaris
Intermittent Jerking and Idle Stall on 2007 Yaris 1.3 (2SZ-FE) with –20 % STFT
Hello everyone,
I’ve been battling an intermittent drivability issue on my 2007 Toyota Yaris 1.3 L (2SZ-FE) and could really use your insights. Below is a summary of what’s happening, what I’ve tested so far, and some live-data readings. Any ideas or suggestions are greatly appreciated!
1.Primary Symptoms:
- Jerking under light throttle or cruising – It feels like the ECU is abruptly cutting fuel when the STFT drops into large negative trims.
Occasional idle stalls – Usually when stopping or coming to a slow roll (e.g., at a stoplight), the engine will dip toward 600 RPM and sometimes stall altogether.
Variable occurrence – It does not happen every time; sometimes I drive for 30 minutes without incident, other times it happens multiple times in a single trip.
in any case, once warm, the idle is pretty low w/ the AC off.
2. Key Scan-Tool Data (Warm Idle)
Short-Term Fuel Trim (STFT): Dips as far as –20 % right before the jerking/stall.
Upstream O₂ (Bank 1 Sensor 1): Cycles smoothly between 0.07 V ↔ 0.70 V at idle (≈1 Hz oscillation)—indicating a healthy heated zirconia sensor.
Downstream O₂ (Bank 1 Sensor 2): Steady at 0.60 V – 0.65 V, as expected with a good catalytic converter.
3. What I’ve Already Checked
– Pretty new NGK OEM Plugs.
MAF Sensor & Intake:
– MAF reading at idle = 1.2–1.4 g/s
– Throttle body cleaned (top and bottom).
– Intake manifold and vacuum hoses looks ok.
-Coolant temp looks accurate.
No Stored DTCs:
– ECM logs no check-engine light, no pending codes, no misfire codes, no O₂ or sensor faults. also tested by 2 mechanics with Toyota special OBD.
Thank you!!!
Or05230 is offline   Reply With Quote
Old 06-30-2025, 07:40 PM   #2
robkay
Drives: Hatch
Hey, I might be having the same problem. At least similar.
2007 Hatchback. A couple weeks ago I noticed when I was slowing down to stop I had the same sort of symptom, although it did not stall. I switched off the A/C and the problem did not continue, but that might have just been a coincidence.
I mentioned it to my wife and she said she noticed it once the day before but didn't say anything because she thought it might just have been a fluke.
A couple days later she drove it again and said she had a lot of trouble with it. She was worred that it was going to stall out on her, although it did not. She said it didn't matter whether the A/C was on or off.
I took it to a reliable local shop. They had the car for a week and guys drove it and said they didn't have any problem--except the owner commented that when he was driving it in to the lift it made one very slight "bump."
So, we just picked the car up and within a mile of leaving the shop my wife pulled over and said it was acting up on her. So, we switched cars and I drove it the rest of the way home and i didn't have a problem
So, as you say, it's an intermittant issue. It's unsettling because you don't want to get stuck somewhere.
Oh--I checked for stored codes with a BlueDriver and there was nothing. Strange this is happenind and no stored codes.
I hope someone can offer some insight on this for us.
robkay is offline   Reply With Quote
Idle issue on 2007 Yaris 1.3 VinceSA DIY / Maintenance / Service 10 12-09-2020 12:43 PM
