Old 07-03-2019, 12:01 PM   #1
YodaBird
Drives: Gray
Splotches of condensation ?
Why am I getting these white spots, what I assume is condensation on only one side of my front head lights, particularly where the sun hits ?
How do I remove it or clean it or prevent it ?
YodaBird is offline   Reply With Quote
Old 07-05-2019, 05:32 PM   #2
NotSaintPatrick
Drives: 2007 Toyota Yaris T Sport 3dr
Are you sure that's not the plastic starting to fade? I thought I had the same problem on my 07 hatchback, but it turned out to be fading. I had to wet sand them down and clear coat them with UV clear to fix it.
NotSaintPatrick is offline   Reply With Quote
Old 07-07-2019, 09:53 PM   #3
YodaBird
Drives: Gray
I've had to move my car where more sun hits the car for the past three weeks and I began to notice this on the one headlight, could this be the cause ? If so, this is frustrating.
Old 07-07-2019, 10:06 PM   #4
tmontague
tmontague's Avatar
Appears to be oxidation, depending on the year of your car that is normal on virtually every single car on the road after time.
Wet sand from 1k up to 3k then polish and cover with a ceramic coat. I have done the uv resistant clear coat but eventually even they start to turn light yellow and they all crack/flake eventually no matter how well you prep the surface. Ceramic coating that is reapplied every year after you clean them up works much better imo.
Or better yet, buy new headlights off of ebay for $100usd. That's what I did and they look great and have held up very well with a ceramic coating over them.
Old 07-07-2019, 10:24 PM   #5
YodaBird
Drives: Gray
When I wipe it, it appears to go away, I should try again tomorrow; then it immediately comes back. It's 2012.
Old 07-08-2019, 10:22 AM   #6
pjon
Drives: Yaris Icon+ 1.33 vvti
I, too get this. It does wipe off though and gradually returns. I also get some internal condensation, in winter, that evaporates when the sun shines or the headlights are used. It appears in what looks like a double skin at the top. The same place as the exernal "clouding" appears.
The handbook states that some condensation is quite normal - really? I did take pictures and show the selling dealer, who followed the handbook line, "At that extent, quite normal."
pjon is offline   Reply With Quote
Condensation from air vents brad14880 DIY / Maintenance / Service 5 06-19-2018 05:01 PM
TYC Tail Light Condensation MadMax Cosmetic Modifications (Exterior/Interior) 7 10-14-2011 11:15 PM
Headlight Condensation darkmoon87 Cosmetic Modifications (Exterior/Interior) 11 06-24-2010 06:21 PM
condensation in the headlights waxxer Australia 2 04-26-2010 08:01 PM
Will missing door vapor barrier contribute to condensation when it rains inside? YarisSedan General Yaris / Vitz Discussion 4 02-11-2010 10:18 AM
