![]() ![]() ![]() Drives: yaris hatch 07 640K original m Join Date: Mar 2007
cranking amps
Maybe someone here has measured the starting amps on the 1.5 engines with one of those amp clamp tools. I want to know just what it draws. I have a start module that works with a battery and it dumps about 220 amps out on start and then a small battery can supply about 200 amps also if needed.....The module might be modified to reduce that amount with an appropriate resisitor...but I want to know what the numbers are
before I use it.. I would guess the 1.5 uses about 150 amps during the summer and maybe 200 in winter,,,?? what do you know??? |
| The Intermittent Cranking No Start Yaris VVTi mystery continues. FASTTEC used. | YarisVVTi2002 | DIY / Maintenance / Service | 2 | 09-16-2019 06:43 PM |
| Constant cranking | attrapereves | General Yaris / Vitz Discussion | 1 | 09-21-2015 07:55 PM |
| unauthorized amps | patm | In Car Entertainment + Electronics (audio / video / alarm) | 12 | 04-03-2012 02:28 AM |
| Two amps one fuse? And hu install? | FuuFuu | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 12-24-2011 12:33 PM |
| Slow cranking on an 02 1.0 vvti Yaris | Duberry | UK | 0 | 11-01-2010 10:20 AM |
