![]() ![]() Drives: Olive yaris,FRS, Dakota R/T Join Date: Aug 2013
Changing out a plug in 2007 Yaris sedan
Getting misfires on cylinder 1( started a thread on that). Wanted to look at plug . Here’s some pics and tips.
Thexton 492 spark plug starter . Old plug boot or rubber hose works too. If plug is cross threaded hose will slip
Plug threaded in
I then bottom it with extension /spark plug socket. I have a 1/4 adapter for 1/4 torque wrench. I spin up and down to make sure plug moves freely and no cross thread. It will feel gritty because of carbon deposits on threads in spark plug hole.
Torque spec is 13 lb ft or 156 inch lbs. I set wrench to 170. I’d rather err slightly tighter than looser. 1/2 turn seated plug gaskets. I actually loosened again and spun plug up and down to again checking for cross thread.. Torqued again this time 1/4 turn til click because gasket on plug was crushed. If the plugs been in a awhile sometimes a 1/8 turn will click.
Super lube dielectric grease in coil . A dab put in top of boot.
Torquing coil 10mm bolt to 80 inch lbs.
Torquing cover 10mm bolts to 80 inch lbs
And if you loose the insert washer on top of cover a 7/8 washer fits
| 2007 yaris sedan aux jack... | chief ten bears | In Car Entertainment + Electronics (audio / video / alarm) | 13 | 10-26-2016 11:38 AM |
| Tein Street Basis Coilover Install - 2007 Yaris Sedan NCP93 Stock | sheekeebut | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 06-13-2014 01:32 AM |
| 2007 Yaris Sedan Front Grille | Stacieee | Cosmetic Modifications (Exterior/Interior) | 1 | 05-29-2012 10:48 PM |
