![]() Drives: 2008 Yaris 3dr Join Date: Nov 2018
Oil Change Accessories
Purchased a 2008 Yaris with 58,000 miles. Need to do my first oil change on it. Unfortunately due to apartment moves I had to jettison stuff like my oil drain catch pan and storage jug. Trying to remember the last one I used. Can anyone recommend a good catch pan? I went to Chris Fix's site and sees he recommends:
https://www.youtube.com/redirect?q=h...AxNTYzOTE0NzAy I used to have a different style. Thoughts appreciated. |
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
I have one similar to that, but the top isn't as deep. I got it at wal mart for like 12 bucks and works fine.
I'm a hermit named Lee |
I use this:
https://www.amazon.com/Capri-Tools-C...dp/B00JJ63RNS/ Perfect size for the Yaris. Slides right under car. Can do oil change with the car on the ground. No need to jack it up. 2 gallon capacity. Very sturdy, integrated lip makes it easy to empty. I haven't spilled a drop since I started using it. 5 star item IMHO. |
A nice little trick is to cut a Mobil 1 quart bottle in half to use as a funnel. The threads on bottle top match the threads on the valve cover. Just screw it in and pour. No need to do the one hand pour, one hand hold the funnel shuffle.
![]() ![]() ![]() ![]() Drives: 2009 Yaris--3dr MT Join Date: Jan 2011
Just curious, how much does an oil change cost you guys when you do it yourself? I've taken mine to the dealer since day one, which in the long run is probably not the wisest move if I want to save money. And what do you do with the old oil once it's drained? Thanks.
#7 | |
![]() Drives: 5 spd MT,black ASA iwheels Join Date: Jan 2012
Sent from my SM-N910T using Tapatalk |
| 2ZR Turbo Yaris | 06YarisRS | Forced Induction Forum | 562 | 08-28-2025 03:49 AM |
| Question replacing head gasket. | Snyprwlf47 | DIY / Maintenance / Service | 3 | 07-14-2014 12:17 AM |
| Oil filter seeping oil from seal : Should I change it ? | Hershey | DIY / Maintenance / Service | 33 | 11-14-2012 05:25 PM |
| First DIY oil change but... | derickveliz2 | DIY / Maintenance / Service | 31 | 02-02-2009 12:36 PM |
| Oil change question | Ryu | DIY / Maintenance / Service | 22 | 03-08-2006 12:21 AM |
