![]() ![]() Drives: Olive yaris,FRS, Dakota R/T Join Date: Aug 2013
Alternator , thermostat water pump replacement
Here’s some pics of my Yaris under the knife
Last pic was Chapman driver (that fits) removing philps screw on a/c line support that when bolt underneath is removed it can moved down out of way
Armstrong 11-994 ratchet 3/8 to 1/4!adapter 14mm socket lower alternator bolt. Upper is 12mm
No room to pull lower alternator bolt out with ratchet so I used a 14mm locking flex head wrench angled to fit between alternator and a/c lines.
Alternator out there’s your water pump
And the thermostat housing
Note the rusted nutin last photo .Whole stud came out with but seized to it. Bought a new stud and nut.
Use hose clamp pliers on lower road hose to thermo housing
Hose off.
I pulled thermostat out with a hook and pick
New Thermostat and o ring. Out new stud in block with stubby 1/4 ratchet and 4mm socket. Cleaned housing with acetone/rag. Nuts are 10mm. Reassembled
You should remove water pump pulleys bolts with belt on. I didn’t and put a 9 inch 1/4 extension to prevent pulley from turning. Scared back of pulley a bit. I used a new pulley so wasn’t concerned .
I removed 10mm water pump bolts/nuts with a 8 inch matco 1/4 drive ratchet . Lowest bolt is near the hump in pump at bottom. I accidentally removed timing cover bolt that is very close to water pump bolt.
Removed pump. Far right is bottom bolt hole that’s hard to tighten and close to timing cover bolt . Note dried pink coolant
Tightening stud . Pump has 2 studs with 2 nuts and 3 bolts.
Used permeated gasket remover and a razor blade at 90 degree angle. Ended up massaging goo gone oven cleaner on timing cover with m thumb 3 times . Throughly rinsing with water .
Install new gasket and pump . Tighten to 11nm or 97 inch lbs. I used 100 inch pounds. Shown is gearwrench torque wrench between pump and firewall. The back nut and bottom bolt had to be done leaning on engine cover torque wrench towards firewall.
Before torquing I tightened with little 3 inch tekton 1/4 ratchet. Then final torque with torque wrench
| Water pump replacement guide? | Mrb | DIY / Maintenance / Service | 5 | 02-05-2019 02:05 PM |
| Odd Fuel pump issue. Feeling at a loss. | Marchalis | DIY / Maintenance / Service | 4 | 03-06-2018 09:55 PM |
| Location of Water Pump | lululovesu | DIY / Maintenance / Service | 1 | 10-19-2014 09:05 AM |
| drive belt replacement and/or water pump replacement | sociolog | DIY / Maintenance / Service | 9 | 02-10-2014 01:33 PM |
| Rear Shocks Replacement? Water Pump. | babytic | DIY / Maintenance / Service | 7 | 06-15-2013 04:55 PM |
