![]() ![]() Drives: 2007 Yaris sedan Join Date: Nov 2011
Poor gas mileage...
Hello all,
Recently I've noticed a large decrease in my MPG. I know it is winter time and I expected my MPGs to decrease slightly for things like warm up time and low tire pressue, but I think what I am experiencing is more than this. I reset my odo trip last time I filled up as a little experiment. Most of my driving is highway. For this tank of gas, I have gotten just under 230 miles. When my car alerted me that I have about 1 gal left in the tank. This is the worst gas mileage I have ever had while owning the car. Before the winter hit, I did a spark plug replacement as well as a coolant change. This was the last maintenance I did before experienceing the lower MPGs, I used NGK laser iridium spark plugs, checked the gaps of all, and made sure they were torqued down correctly. The last ones i took out were denso iridiums that had much larger gaps outside of the spec limits for the yaris with very worn tips, so i was expecting an increase in MPG. Also, I used toyota pink coolant. This weekend, I am doing an air filter clean (K&N) and a seafoam treatment on my next fill up to see if this helps. I have been checking tire pressure frequently and made sure to keep the tires around 32 psi. I still have another 1000 miles or so before the next oil change. I always change the filter and I use pennzoil platinum high mileage. I have checked the car's computer with a code reader and its not giving any codes for anything funky. Any other ideas? Thank you, 400 |
| -Mileage Thread- -Log your mileage, year, model, color, any problems here... | Kal-El | DIY / Maintenance / Service | 322 | 07-20-2016 11:07 AM |
| Amazing Gas Mileage .. way too easy. | edmscan | Fuel Economy Forum | 9 | 07-19-2012 07:36 PM |
| Does Gas Mileage Increase After 1st Oil Change? | ChilliwackGuy | Fuel Economy Forum | 10 | 08-04-2010 03:13 PM |
| 2009 Yaris Mileage | wornways | Fuel Economy Forum | 3 | 07-29-2009 12:42 PM |
| Performance mods that won't affect/will hardly affect gas mileage?? | Mr.Yaris | Performance Modifications | 15 | 07-30-2007 01:32 AM |
