10-12-2019, 07:41 AM | #1 |
Drives: 06 2ZR Turbo Yaris RS Join Date: Aug 2017
Gauges...Check this out
I wish I'd known about this before I proceeded with hacking my dash all up!
https://www.youtube.com/watch?v=e13j0bm7Si8
10-12-2019, 01:23 PM | #2 |
Drives: '08 2zr swapped Vios M/T Join Date: Oct 2012
hmm, that is a great innovation and design for sure. My concern is that the gauges are limited to what the factory ECU reads. Meaning in a car like the Yaris you can view things like coolant temp but not important data like oil temp and pressure. Correct me if I'm wrong but this is essentially just like an ultra gauge that obtains all of its readings from the OBDII port
No one ever wants to give a Yaris the point by... |
10-12-2019, 08:54 PM | #3 | |
10-12-2019, 10:31 PM | #4 | |
01-07-2020, 08:10 PM | #5 | |
Drives: 2009 Yaris 2dr Liftback Join Date: May 2019
They are ludicrously priced $399 USD. https://www.bankspower.com/i-2760-ba...7Cyear%3D2009v I ended up getting a cheap Chinese OBD2 gauge from amazon. I have it set up to display speed, RPM, water temperature, and battery voltage. https://www.amazon.com/VJOYCAR-Speed...8445643&sr=8-1 |
01-07-2020, 10:36 PM | #6 | |
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 01-07-2020 at 10:49 PM. |
01-08-2020, 09:19 PM | #7 | |
The chinese stuff does what I need it to, and the banks gauge would be overkill for my needs, and that's why I thought the price was high. However, if the one banks gauge replaces your gauge cluster, then I can definitely see the value. |
01-08-2020, 11:05 PM | #8 | |
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Anyone put in gauges into radio location? | end user | DIY / Maintenance / Service | 2 | 03-18-2016 11:50 PM |
help..check engine again | dindy | DIY / Maintenance / Service | 12 | 12-13-2012 06:17 PM |
MAF check engine light and transmission help | heeroyuy01195 | DIY / Maintenance / Service | 22 | 04-03-2012 02:16 PM |
check engine light twice within a week of purchase?? | conurebuddy | General Yaris / Vitz Discussion | 8 | 04-17-2009 10:53 AM |
Paying for the Yaris with a check? | YotaYarisUSA | New YARIS Purchase Forum | 15 | 07-11-2007 03:31 PM |
