![]() ![]() ![]() ![]() Drives: 2009 Yaris--3dr MT Join Date: Jan 2011
Do I clutch in when shifting into neutral?
Hi YWers. I know, this is a driver's ed question, and probably something I should know by now. But I've never been entirely clear on this issue, despite having a couple manual cars before buying my manual Yaris. For all those who drive manual cars out there, do you push the clutch pedal in when you shift into neutral? I always have, but am not really 100% sure if it's even necessary. Thanks in advance for any help on this remedial question.
Yes.
Yes
Yes, clutch in when you put the shifter in neutral. And something that's very important that I don't see many people doing...release the clutch pedal once you're in neutral. Don't keep it depressed. You're going to cause a lot of premature wear on the TOB.
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
Clutch in whenever you do ANYTHING in a manual. Some people clutchless shift but I'd rather replace a clutch than a transmission, so I use the clutch. Sometimes I subconsciously double clutch, its pointless but doesn't harm anything in a synchronized transmission.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
You guys are awesome. Thank you!
Obsessed with 1.5L
Drives: '10 PW Yaris Sedan Join Date: Feb 2011
I dont lol. Whem Im causally driving I actually back off the throttle a smidge to reduce the load and pull into into neutral then clutch in then go to next gear. I dont recommend this but I do it in all my manual cars.
-Greg...the Exhaust Freak. -10 PW sedan 107whp/110wtq, full exhaust, suspension bits, TRD LSD -06 Highlander 3mzfe Limited AWD -82 Malibu, 1uzfe swap -97 Tercel coupe, 1nzfe/4.31 -96 Tercel coupe, Turbo 5efe, autoX -96 Tercel 4dr |
Sometimes. Most of the time.
But then sometimes I shift from 3rd to 4th and 4th to 5th w/o using the clutch. It's possible if you're at the correct RPM.
- The Black Ship Yaris - |
Sometimes you don’t have to if you know what you’re doing. In fact it isn’t necessary to use the clutch at all except for starting off from a stop.
Now that you mention it.
![]() ![]() ![]() Drives: 2013 NCP130 Join Date: Nov 2015
I learned how to do that when driving my friend's 18 wheeler, which has a 15 speed Road Ranger gearbox. These were a constant mesh gearbox like most motorcycles. It allowed for much faster gear changes than double clutching.
For a bit more information, this is a 5 speed shift with 3 ranges - High, Low and Deep Reduction. Normally, the Deep Reduction range wasn't used on the road unless you needed to do a hill start with a full load.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam. |
| Clutch Maintenance | fnkngrv | DIY / Maintenance / Service | 12 | 03-03-2017 10:42 AM |
| Aftermarket Clutch Q's | tmontague | Performance Modifications | 5 | 03-05-2016 04:33 PM |
| need help on my 2008 yaris compress clutch | susucosp | DIY / Maintenance / Service | 0 | 05-15-2014 03:48 PM |
| Q: when shifting into neutral... clutch? | yarisugi | General Yaris / Vitz Discussion | 31 | 04-19-2012 10:51 PM |
| Shifting without the clutch | mark293 | General Yaris / Vitz Discussion | 91 | 07-12-2010 08:56 PM |
