Old 06-20-2019, 04:17 PM   #1
justanotherdrunk
justanotherdrunk's Avatar
Drives: 2016 SE
speedometer calibration
the latest android maps update finally includes the speed and speed limits so i wanted to check the accuracy of the car vs the app
i guess 1 mph deviation at 80 is decent
red means toooo fast!
Old 07-09-2019, 02:55 AM   #2
toyotavios_11
Drives: Toyota Vios
GPS itself wont be accurate too
toyotavios_11 is offline   Reply With Quote
Old 07-09-2019, 02:37 PM   #3
ern-diz
ern-diz's Avatar
Drives: 2007 Liftback
Fun and interesting to look at.
On Instagram
On Wheelwell
Old 07-10-2019, 10:27 PM   #4
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Here in Australia it will most likely be much more accurate that the speedometer. My speedometer shows 80 km/h at a GPS indicated 76 km/h. This agrees with the readings from the OBDII port using the Torque app.
Australian regulations say the speedometer must not show a speed lower than the correct speed, but may read high by up to 4% plus 4 km/h.
Does anyone know if it is actually possible to adjust the speedometer? The last time I touched a speedometer to recalibrate it was 20 years ago on a Jaguar. A previous owner had the trip meter repaired, and the repairer did not correctly reset the mechanical zero...
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
Old 07-10-2019, 10:43 PM   #5
NYC-SE
NYC-SE's Avatar
Drives: 2014 Yaris SE
Yes here too speedometers read higher than actual speed. Annoying. I can deal with a 1mph error (like OP shows and as I have verified on my own Yaris as well) but I've driven some cars where they were off by 4 mph or so. Really annoying. GPS is generally more accurate.
Old 07-19-2019, 07:10 AM   #6
pjon
Drives: Yaris Icon+ 1.33 vvti
Speedometers here in the U.K. may read up to 10% higher than actual. Never lower.
Thanks for posting the info. re G Maps speedometer. I didn't know it was finaly available. Now found in settings and activated.
pjon is offline   Reply With Quote
Old 07-20-2019, 03:26 PM   #7
justanotherdrunk
Drives: 2016 SE
Old 10-08-2019, 07:12 AM   #8
hmsailor
Drives: 2015 yaris hatchback
mine is 2mph off. this is from actual speed radar.
hmsailor is offline   Reply With Quote
Old 04-20-2020, 10:23 PM   #9
blktiger60
blktiger60's Avatar
Drives: `08 HB S
Unless you are running OEM diameter tires your speedometer will not give accurate info. Smaller diameter tires will give faster speedo readings.
- The Black Ship Yaris -
blktiger60 is offline   Reply With Quote
Old 04-25-2020, 11:13 PM   #10
SECProto
Drives: 2012 Yaris LE
I just got a new phone with this feature. Confirmed that my speedometer, the roadside speed display thingies, and the GPS all read identical speeds within ~1km/hr
(and I am on OEM diameter tires.)
SECProto is offline   Reply With Quote
Old 04-26-2020, 04:40 AM   #11
Manufacturers have leeway in speedometer tolerances (I thought I remember reading up to 6%, but don't quote me on that).
Yeah, GPS aren't accurate either. You'd have to get one of those fancy devices that they use for record attempts if you want super accurate speeds. lol
Old 05-20-2020, 05:57 PM   #12
Sia
Drives: Toyota Yaris 2008
Hello, I have a Toyota Yaris 2008 and its speedometer shows a way higher speed. If it is 20 mph it shows 40 and if it is 30-40 it shows 60 mph. Is this something easy I can fix it?
Sia is offline   Reply With Quote
Speedometer calibration Stiv DIY / Maintenance / Service 2 04-20-2020 09:54 PM
Inaccurate analog speedometer JudgeM DIY / Maintenance / Service 2 12-23-2014 06:00 PM
Analog Speedometer instead Digital Sesjusz DIY / Maintenance / Service 7 07-01-2014 12:42 PM
Tacho , Speedometer with fix on my car selimesen007 DIY / Maintenance / Service 0 07-11-2013 06:20 PM
Speedometer Calibration / DeMetrification CTScott DIY / Maintenance / Service 17 10-06-2012 10:00 PM
