Old 08-28-2020, 02:44 PM   #1
johannes2k
Drives: Yaris
1NZ-FE (TS) - transmission fluid change, 1.9 liters or let it overflow?
Hi,
I have a Yaris T sport from 2001 with the 1.5 liter engine with the manual 5 speed gearbox.
I changed the trans fluid today, the toyota dealer (and the manual) stated that it would take 1.9 liters, i did add 1.9 liters but it didnt flow over the lip. Should I add more or let it be?
Thanks
/ Sweden
johannes2k is offline   Reply With Quote
Old 08-28-2020, 10:24 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by johannes2k View Post
Hi,
Thanks
/ Sweden
I'm interested in the answer to this too. I will be doing mine soon. From the brief reading I've done, I think you just keep pouring until it starts to dribble out of the upper plug. What gear oil did you use?
Old 08-29-2020, 03:20 AM   #3
johannes2k
Drives: Yaris
Yeah, I hope we get some answers! I saw another guy that asked the same thing, hes transmission didnt overflow when adding 1.9 liters.
I used the Castrol Syntrans Multivehicle 75W-90, it's API GL-4. Do not use a GL-5, even if the manual say so. ( https://www.yotatech.com/forums/f116...gl-5-a-201741/ )
Old 08-29-2020, 03:22 PM   #4
Brighton
Knower of little
Drives: None
If the dealer said an actual amount then stick with that. Normally filling until it spills out the fill hole is standard procedure for pretty much all cars/trucks/bikes etc. But that's only if actual measured amounts aren't available.
Brighton is offline   Reply With Quote
Old 08-29-2020, 08:32 PM   #5
stykerdk
Yaris Hybrid Limited 2015
Drives: yaris Hybrid limited 2015
You should really stay with the Toyota 75w GL4 oil, or you probably get bad shifting, these old toyota gear boxes dont like multigrade oil.
https://www.ebay.co.uk/itm/Genuine-T...-/282917939837
This should be the same at a much higher price for our US friends.
https://www.ebay.com/itm/LEXUS-TOYOT...-/233126119936
C-HR 1,8 Hybrid premium 2020
stykerdk is offline   Reply With Quote
Old 08-30-2020, 03:31 AM   #6
johannes2k
Drives: Yaris
Thats not what the toyota dealer stated nor the manual tho, not for this gearbox.
2012 Yaris hatchback, 5MT: when to change transmission oil? matti General Yaris / Vitz Discussion 14 11-18-2016 12:23 AM
Manual Transmission fluid change bankrobber DIY / Maintenance / Service 1 01-17-2010 10:32 AM
Maintenance - Change Auto Trans Fluid Linkseal DIY / Maintenance / Service 1 08-15-2006 10:57 PM
