![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Came across this disc conversion..
https://www.youtube.com/watch?v=edxgGu8YZZs
They have kits for 2005 onwards. Basically it keeps the drum functionality for the ebrake only and uses a caliper for the braking. Found it interesting. http://unique-power.com.tw/ https://i.imgur.com/3VtSWQX.png |
#2 | |
"As our understanding, Yaris is all the same through different generation. Please refer to our website, check the installation guide for Yaris. If the bolt of the hub is the same, they should be all the same".
Contacted
I contacted.
Waiting back for more info for 2007 HB If price is reasonable then I may get. Its easily DIY. The Kit looks to be really well made. Its also mentioned in the comments other calipers and pads can be used.Those are not specific for this setup. |
Awesome. Can't wait to hear about it. Wonder if it would make sense to order an extra set of discs and ebrake drum pads.
The drum pads dont really concern me as they will only be used when parked.Cant see those wearing down with no movement/friction.
The disc drum does concern me though. If it does work for 2007 models then its probaly the easiest way to get disc setup plug and play. No need for modifications like other disc conversions(Runstop)and either having to replace axle(SE) part like mentioned on other threads |
![]() Drives: Black 2012 SE manual Join Date: Feb 2013
First I know nothing about any of these rear brake conversions... could there be from the plant some sort of front/rear proportioning valve to handle differently the two setups available according to trim ? considering what little duty rears do I would be tempted to retain drums as I feel in our Canadian climate an enclosed system handles better salt exposure and corrosion !
#7 | |
update..
Thanks for your inquiry. Yes, we have a kit that fits Toyota Yaris perfectly. Please refer to the installation guide attached. This kit is about US$800 in Taiwan with installation fee included. Standard export price is US$580 plus shipping. Please inform your location in order to estimate the freight. We are pleased to provide you with discounts if you are interested. Please feel free to ask any questions. |
#8 | |
I also agree that the stock drum setup would be better sealed for Canadian winters, though my turbo RS never sees winter.
cost
580 USD is reasonable to me.
Curently waiting for quite. I have US address to save on ship. |
Oh, I misread the response. I thought that it was $800.00 + $580.00 + shipping. I agree, $580.00 is very reasonable. Please let me know what you're quoted for shipping.
Not sure know that I think about it.
Not exactly sure what export price means? I assumed by the wording that if you were in thailand the price was 800 including installation And the cost for the item was 500 plus shipping. I will post back when I get the quote and ask them total price for the whole deal. |
#12 | |
If it is indeed 580 I will be ordering for sure....ship cost depends too?
Saw this on reddit (Thai Post Logispost service (Air Freight) shows USD 236 for 30 kg) Also this(400 Baht /kg...400baht is 16.80 CAD. |
Are you estimating the weight of the kit or have they given you an estimate on the weight? At 30 kg, I'd be looking at $500.00 shipping, plus import charges, and tax (15% in my province). Not including import charges, I'd be looking at close to $1500.00 CAD.
Not a quote from company.
Those are just quotes,or replys from an older reddit thread about shipping from thailand to US.
I just googled (shipping from thailand to the us cost reddit) I use reddit quite a bit for good info. Reddit is a wealth of info and help. Its my favourite site in the way you can interact. Its not like the normal forums. name it and there is a subreddit/group for it. They are slow to reply back,or the time difference aswell? P.S dont ship it into Canada. I use (crossborderpickups.com) Many other companies thar do the same. I save huge on import duties. I paid $60 cad total for 4X wheels into canada. I also saved bigtime as the us company shipped free within us. |
#16 | |
confusing message from seller
(Thanks for your prompt reply. We do not have this model available for confirmation in Taiwan. However, according to our experience, no Yaris has reported installation problems in many countries so far. Moreover, it is not a cost-effective thing for automakers to modify the brake structure of the same series of cars at will. Sending 20 kg to the State by the TNT Express during this virus outbreak is US$180. Our best offer is a 20% off discount plus shipping. Total = (580 x 80%) + 180 = US$644 for all) |
#17 | |
I am interested in how the valving is done so that the brakes aren't too strong in the rear. I'd expect that with calipers vs the tiny wheel cylinders, there'd be some changes in forces. Also, like with the big brake swaps, would we expect a mushier pedal? The guys that did the upgraded fronts from Yaris to xD or Corolla suggested that a larger diameter master cylinder might be needed.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 10-14-2020 at 12:03 PM. |
Fitment & ship
info@unique-power.com.tw
The shipment quote was to an americam address btw the way for me. Niagara falls new york. The ship is def reasonable.. Too bad no 100% confirmation that it will work 2007 3 dr. Perhaps some others will chime in. Surprised actually that others have not commented yet? It def looks to be well built. Somewhere in the comments manufacturer mentioned no need for master cylinder upgrade,and it balances itself out properly. |
| Rear axle swap out for disc brake upgrade + 5 lug conversion | Neinris | Cosmetic Modifications (Exterior/Interior) | 48 | 08-13-2025 08:25 AM |
| DIY (sorta) - RunStop Rear disc brake conversion | eTiMaGo | DIY / Maintenance / Service | 17 | 07-02-2019 09:24 AM |
| Rear Drum to Disc Brake Conversion | Mark-UPI | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 40 | 03-13-2015 12:26 AM |
| drum brake conversion to disc brake | bogartvitz | Performance Modifications | 8 | 04-15-2013 11:21 PM |
| For those who have the rear disc brake conversion | mrbond | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 22 | 06-05-2009 05:01 PM |
