Old 10-19-2020, 08:53 AM   #1
serendipity
Drives: Toyota Yaris
Yaris stalling in very hot weather at low rpm
Our 2008 4sp automatic 1.5l Yaris sedan stalls intermittently or loses power at low rpm in very hot weather (>35C/100F). Car has 150k kms and has been doing it since around 80ks. Car is completely stock.
The most common set of circumstances is after car has a long period of idling or lots of stop/start driving or slowing down after a long period of highway driving. It starts again immediately with no issues. If temperature is less than 35C/100F then doesn't seem to be an issue.
No engine codes have been recorded. Fuel filter in the tank has been replaced recently and resulted in no change. Throttle body has been cleaned. Spark plugs replaced. Car uses E10 fuel.
To my inexperienced mind it seems like it may be a vapour lock although it does not appear to be related to amount of fuel in the tank.
Any help would be much appreciated!
serendipity is offline   Reply With Quote
Old 10-19-2020, 08:00 PM   #2
ex-x-fire
Try cleaning the MAF sensor. It could be very dirty injectors or weak fuel pressure.
Old 10-19-2020, 08:18 PM   #3
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Please only start one thread per issue.
Old 10-20-2020, 11:36 AM   #4
alanwagen
The Throttle body by the butterfly usually has a build up which would cause restriction when idling. Get some long cotton swabs and throttle body cleaner.
Old 10-21-2020, 11:38 PM   #5
toyotavios_11
Drives: Toyota Vios
i think it is quite common for Toyota old models to have low RPM (500-500rpm) at idle.
some say replace A/F (O2) sensor will resolve it, but soon after a while the problem comes back again
toyotavios_11 is offline   Reply With Quote
England to the Nordkapp and back in my Yaris zoidberg444 Photo-Video-Media Gallery 15 07-27-2020 09:09 AM
Toyota Yaris Optimal RPM for Highways Anquietas General Yaris / Vitz Discussion 12 04-28-2017 06:59 AM
Engine fan on when standing still and low mpg 2002 yaris andqe DIY / Maintenance / Service 5 09-15-2012 04:32 PM
