![]() Drives: big one Join Date: Apr 2013
Yaris T1 (1kr-fe) (998cc) aviation conversion
Hi All,
Hope someone can help me on this. I'm converting the above motor for aviation use ![]() and need about 15hp more out of the stock motor at 6000rpm (climb/takeoff). Cruise is at ~5400 rpm. The rest of the RPM range don't get used (except for idling of course which can be anything from 1000-2500rpm ).So, I was wondering what will the easiest mods be. Noise is not issue. Fuel usage not issue. low -> mid range power not issue. I have to change the throttle body from the "drive by wire" system to standard cable and so I can fit larger bore if that will help. (Also don't need TPS sensor as throttle will always be advanced/retarded slowly) Regarding the VVT-I. My understanding it only assist in mid rpm boost, don't do much or high rpm, is this correct? Otherwise I can simple activate it fully at X rpm and make it VVT (without I) as the older motors was. Any input appreciated. L: |
| Do you like the 2012 restyle? | hitmoninfinity | Third Gen Yaris General Discussion | 106 | 04-14-2016 09:08 PM |
| Yaris vs MR2 Spyder | regal | Off-topic / Other Cars / Everything else Discussions | 35 | 06-03-2010 07:50 PM |
