Old 08-14-2015, 08:16 PM   #1
Innovative 1
Drives: 2007 Yaris HB 5spd
JUN Auto high lift cams question
RHD japan sells the JUN HIGH LIFT CAMSHAFT - REGULAR SERIES TOYOTA 1NZ-FE which I want. Says on notes that they will not work with stock oem ecu. Then right below it says "The camshaft already adjusted the valve timing. It is bolt-on camshaft which can use with stock valve spring and computer."
Little confused. What does this mean? If anyone can help explain let me know please and thanks peoples
Innovative 1 is offline   Reply With Quote
Old 08-17-2015, 09:20 AM   #2
scod4025
Drives: 12 LE 5d HB 1nz-fe Automatic
the difference you are looking at is in the name
■Bolt-on Camshaft Series
■Regular Camshaft Series
the bolt on series will work with stock ECU
the Regular series will need to have tuning done for it to work properly
so would need some kind of cam control ie stand alone ECM and possibly update of valve springs
so if you don't have control over the cam timing you can use the bolt on series but not the regular series(might be able to but would be very risky most likely just wouldn't fire but could hit valves)
scod4025 is offline   Reply With Quote
Old 08-17-2015, 10:25 AM   #3
0BD1Kenobi
Drives: 2012 Yaris SE
This is in the parts description on rhd
"FEATURES:
Bolt-on Camshaft Series:
- This camshaft already adjusted the valve timing. It is bolt-on camshaft which can use with stock valve spring and computer.
Regular Camshaft Series:
- This series can be used in wide stages from the street spec to the high power engine."
0BD1Kenobi is offline   Reply With Quote
Old 08-18-2015, 07:00 PM   #4
Jason@SportsCar
You would be way ahead of the game working on the ECU first, there is more power there than in the cams, and the cams without tuning only yield a small portion of its potential.
Old 08-19-2015, 11:34 PM   #5
Innovative 1
Please explain the ecu route a bit more if you would.
Old 08-21-2015, 03:02 PM   #6
Jason@SportsCar
Going full standalone, or piggyback, will get you more power than the cams. I have the 9.5mm Jun cams, they make a very small amount of power, and without the ability to tune you will see almost no improvement over stock.
Old 08-22-2015, 12:24 AM   #7
Innovative 1
Like once I install tge power enterprise supercharger with tge p-con sub computer that it comes with?
Old 09-26-2015, 12:11 AM   #8
Berkut
Berkut's Avatar
Drives: Toyota Vitz '05
Keep in mind that Jun shafts produces only for early ver. motor without the rockers.
In the case of installation shafts will need to change the head on the short, in connection with the EGR system will not work.
and put the coil from an earlier version 1nz.
I stand 252 cams with stock ECU, a significant change. Acceleration increases up to the cutoff.
Berkut is offline   Reply With Quote
Old 02-05-2021, 06:56 PM   #9
gaelicfrank
Drives: 2009 JDM Vitz RS 1NZ-FE
So to confirm, the JUN CAMS with NOT WORK, with my 2009 Vitz RS... is this correct?
gaelicfrank is offline   Reply With Quote
Old 02-07-2021, 04:14 PM   #10
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Depends if you have a EGR head or not, US and EU cars don't but SEA cars do. Easy check is to pop your valve cover off and see if you have rockers or solid lifters.
2014 BSpec Divisional Champion
Old 02-09-2021, 01:11 PM   #11
remcafee
i have the bolt on series cams and they i will say they say it works with stock ecu but what they dont say is how the overall drivability is, so what you will experience is about a half a second of increased startup, random misfires for the first 30 seconds on startup, and very bad fue economy, i track my yaris regularly and honestly regret the jun cams as i daily drive it, but performancealways comes woth a sacrifice, if you are ok with uncomfortable driviability issues for a 6 whp increase (i dynoed them before and after) its up to you. im just letting you know my experience with them, if youre daily driving, leave the cams alone, and youre talking about the high lift ones, you NEED a standalone ecu with that one, even the bolt on series struggles with stock ecu i cant imagine the regular series
Old 02-09-2021, 05:40 PM   #12
xnamerxx
0-60 in slow
xnamerxx's Avatar
Rem you'll need to get the car tuned for the cams since it probably wants more timing and less fuel.
Old 02-10-2021, 03:12 PM   #13
remcafee
yeah definitely a tune would help, i cant put it in a piggyback atm as i have emissions where i live
Old 02-10-2021, 03:26 PM   #14
xnamerxx
0-60 in slow
xnamerxx's Avatar
I live in CA have the same issues, reach out to FTGtuning@gmail.com guy is up in Oregon but he can tune the stock ECU.
Old 02-11-2021, 03:15 PM   #15
remcafee
thanks man! didnt know our stock ecus were tunable?
question about parts to be fitted to 1.3L Auto Yaris ASHRAF Performance Modifications 6 12-18-2006 06:16 AM
Handbrake question (Manual vs. Auto) Chaad32 General Yaris / Vitz Discussion 31 07-30-2006 08:03 AM
