![]() Drives: 2015 Toyota Yaris MT Join Date: Aug 2021
How can I seal liftgate wiring to prevent water?
Installed a new liftgate/hatch for my hatchback. All the tabs of this plastic ring from the donor hatch are broken. This results in the rubber boot/wiring/plastic ring to be loose and not form an adequate seal to keep water out.
I don’t want water getting in and soaking my headliner. What should I do? I can’t replace the plastic ring with a new one; the opening of the ring is not big enough for the wiring harness connector to pass through. This is where the wiring is located, for reference: https://imgur.com/a/Z7vLU8n Maybe use some silicone??? I am on mobile. The photo should be rotated 90 degrees clockwise. |
| Installing Trailer Light Harness | vandallen | DIY / Maintenance / Service | 7 | 06-10-2024 11:06 AM |
| Can generic silicone be used to seal a roof channel seam against a water leak? | RMcG | DIY / Maintenance / Service | 6 | 12-27-2022 01:11 AM |
| Water or Water/Methanol Injection DIY | 06YarisRS | Forced Induction Forum | 41 | 06-20-2020 03:03 AM |
| Fuel pump, sender, seal, wiring, and cluster | mavrick | DIY / Maintenance / Service | 5 | 07-22-2019 06:34 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 03:47 PM |
