Drives: 2005 Toyota Echo Join Date: Sep 2020
Hi! I recently picked up a NCP91 TRD Turbo M, and I have installed Advan Racing RC-II 16x7 +30, 205/55/16
For the fronts I will be using 15mm Camber Bolts But i've read the sticky regarding rear camber and about putting washers between the axle and hub on the lower bolts to induce camber. Is there any recommendation on what size washer would be ideal to get slight camber on the rear? Ideally 20mm offset difference? Or are there some sort of shims which are better than using washers? (I can't get anything in google that clarifies) |
| Questioning the Recommended Tyre Widths based on Offset | Energiser | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 4 | 02-24-2012 11:32 AM |
| Bolt Pattern Size and Offset for the Stock Wheels | fmicle | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 08-12-2009 04:35 PM |
| Whats the highest offset and tire size for 17s you could go... | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 9 | 12-15-2008 10:40 AM |
| Transmission Drian Bolt washer size | CB900F2 | DIY / Maintenance / Service | 14 | 12-07-2008 08:03 AM |
