Old 06-22-2007, 08:30 AM   #1
Yarisvene
Drives: Yaris Sedan
Help with low idle from Venezuela
Hello everybody; i'm new here but a silent observer 4 months ago; i am from Venezuela and i purchased a new brand Yaris sedan (this is a new model here); mi car has only 1000 mile and since new i noted that the idle of this car is around only 750rpm but the real doubt is when i turn on the air conditioner, the idle down to 600rpm and the car isn't feel quiet at all; there is normal in this model of toyota that the idle down instead up when one turn on the a/c?, is idle at 750rpm normal in this car?, whats your cars idle? thanks in advance.
Yarisvene is offline   Reply With Quote
Old 06-22-2007, 10:41 AM   #2
||)) (o) ||\||
- Donnie Demonic -
||)) (o) ||\||'s Avatar
Drives: '07 Yaris Sedan Sport
My Sedan would idle anywhere between 1200 and 1500 rpms and shake like slightly enough to notice it. I changed my oil at 7000 miles to Mobil 1 synthetic and now she idles at 750 to 950 rpm with no shake whatsoever. I can barely tell if the car is on... I know it doesnt have anything to do with the AC, because she doesnt idle differently while it is on, but also strange nonetheless..
||)) (o) ||\|| is offline   Reply With Quote
Old 06-22-2007, 10:48 AM   #3
mikeukrainetz
mikeukrainetz's Avatar
Drives: 2006 Toyota Yaris
mine idles around 750 with the air running, most of the time when its not as well.
mikeukrainetz is offline   Reply With Quote
Old 06-22-2007, 11:29 PM   #4
jmjonesey
jmjonesey's Avatar
Drives: Red 2007 Yaris Sedan
Send a message via AIM to jmjonesey
Wow...are you serious
It idles high when you start it up because it is not warmed up.
If you changed your oil to synthetic, it should be idling higher not lower
due to reduced friction.
Sometimes I wonder why I keep coming back here.
But yeah, after my yaris warms up, it idles really low.
jmjonesey is offline   Reply With Quote
Old 06-23-2007, 12:00 AM   #5
Yarisvene
Drives: Yaris Sedan
I went to the dealer and they checked the cpu during 15 mins. and the computer report was 750 rpm without a/c and 700 with a/c, then the MAF sensor was exchanged and same thing; finally the mechanic guy toll me that appanrently this car works at this idle rpm and everything is OK. I still in doubt about this
Old 06-23-2007, 09:23 AM   #6
I see similar idling speeds, between about 650-800RPM when the car is warmed up and the AC running, I think it is normal, it helps maximize fuel efficiency when idling...
Idle Fluctuation due to aftermarket intake? Galavoxx Performance Modifications 38 12-31-2011 09:31 AM
Why do all low profile tires have to be of high performance design? grampi Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 05-16-2007 02:23 AM
Rough Idle in drive toyoman NY / NJ/ CT / PA 8 04-22-2007 04:40 AM
Low idle speed gonzo452001 DIY / Maintenance / Service 9 02-21-2007 09:41 PM
Low gloss plastic/rubber protector product? jay Wash, Wax, Detailing, Exterior Repairs 11 09-10-2006 02:22 AM
