![]() Drives: Yaris hatch Join Date: Jun 2021
fast click sound no start
08 Yaris hatch, just checked battery at 14.4V
turn the key, fast clicking but no start Do these cars have voltage regulator that can be replaced or is it likely the starter or something else? thanks |
![]() Drives: 2008 Yaris RS Join Date: Feb 2021
When you checked the battery did you just touch your meter to the terminals. Disconnect the battery cables and clean them with a terminal and post cleaning tool. Any auto parts store should stock one cheap. Start with that. Also check the connection from the battery to the alternator to make sure it is not corroded. Make sure to disconnect the positive battery cable before doing this. The clicking sound usually indicates the relay isn't getting sufficient power.
![]() Drives: 2007 Yaris Hatch Join Date: Aug 2021
I know you checked the voltage, but did you try jumping it?
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
Could be a bad starter solenoid. You won't know unless you check the voltage drop at the solenoid post, battery connection at solenoid. Try jumping the solenoid to see if that works.
Hold in coil inside solenoid could be damaged Solenoid battery connections corroded or loose Internal solenoid connections corroded Battery connections corroded or loose Starter shorted Starter high resistance Starter open circuit Could be many things, best to check everything with a multimeter and get familiar with voltage drop testing |
twas the battery
It was the battery. Replaced with WalMart Everlast, perfect fit, good warranty,
and relatively cheap. Mercedes has a very inexpensive voltage regulator made by Bosch that is relatively easy to replace, often failing at 60K miles... |
| The Intermittent Cranking No Start Yaris VVTi mystery continues. FASTTEC used. | YarisVVTi2002 | DIY / Maintenance / Service | 2 | 09-16-2019 05:43 PM |
| Vibration on idle & rough start | Murtaza_murti | DIY / Maintenance / Service | 25 | 08-15-2015 12:58 PM |
| Raising the sound stage... | SAV912 | In Car Entertainment + Electronics (audio / video / alarm) | 11 | 07-30-2011 05:26 AM |
