Drives: Toyota Platz 2005 Join Date: Mar 2017
Hi to all!
I have tried to search on this forum and rest of the Internet also, but have not found the answer to my specific query. I have Toyota Platz 2005 1.0L (sedan), manual transmission. I think it is called Yaris Internationally, if I am correct. I want to know the correct gap for spark plug used in this car. Toyota Platz was available with three engine sizes, 1.0L, 1.3L and 1.5L. I bought this car as used, so didn't get any owner's manual. The owner’s manual available on the Internet, for this car is for 1.5L engine only. The spark plug gap mentioned for 1.5L car is 0.8mm (0.031”). Now I want to know, will the spark plug gap be the same for 1.0L also? If someone has specific knowledge about the 1.0L variant, kindly tell me the spark plug gap for it. Also, just for sake of knowledge, wanted to know, what will be the effects, if the gap is little shorter or little wider? Any fuel efficiency? |
The 1 L engine for the Yaris is not sold here in the United States only the 1.5 L. But there may be people who visit this form who would know
In my experience the spark plug gap isn’t terribly important. I had a Harley Davidson motorcycle when I remove the plugs one gap was zero. Someone must’ve dropped the plug before they installed it . When the engine warmed up it ran perfectly it just ran a little rough until it warmed up. Do you have Toyota dealers in Pakistan? I bet they would know.
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
If you are using 90919-01176 then most likely 0.9mm. Some specs for other brands even says at 0.7mm
References: https://www.autodoc.co.uk/car-parts/oem/9091901176? http://www.automobilespare-parts.com...-13575447.html |
| Tags |
| 1.0, gap, spark plugs |
| Spark plug gap? | tomm9050 | DIY / Maintenance / Service | 5 | 10-24-2015 12:21 AM |
| Spark plug gap for 04 echo | donnysdayoff | DIY / Maintenance / Service | 2 | 01-16-2014 09:56 PM |
| Spark Plug Gap | sleey0 | Forced Induction Forum | 7 | 09-21-2010 06:47 PM |
| spark plug gap | Hard_Yaris | DIY / Maintenance / Service | 2 | 06-10-2010 06:23 PM |
| Plug Gap | slvryaris | DIY / Maintenance / Service | 1 | 12-23-2008 11:02 PM |
