Old 10-12-2018, 09:09 AM   #1
Ares5
Drives: Yaris I
problem lights of the dashboard headlights
Goodmorning
I have a problem in the dashboard do not turn on the headlights (position, high beam low beam and anti-fog) but all work! the problem what can be: some fuse? or led of the dashboard or other data concerning the headlights? the car is in second hand and is a yaris I 2001
Ares5 is offline   Reply With Quote
Old 10-13-2018, 06:04 AM   #2
Ares5
Drives: Yaris I
Fuses are ok and led in dashboard are ok
what can be the cause because the lights of the headlights on the dashboard do not light up
Old 10-13-2018, 12:06 PM   #3
tmontague
tmontague's Avatar
I'm not clear on your question? If you are referring to the dashboard lights not going on when you turn on the headlights then the cause it likely your dimmer dial is turned all the way down.
Spin it to full on and your dash lights should light up again
Old 10-13-2018, 06:37 PM   #4
Ares5
Drives: Yaris I
Yes , I turn on headlights and lights oft headlight not going on the dashboard, I move dimmer up or down but not happen nothing, I push botton about fog light but not turn light on the dashboard
Old 10-13-2018, 06:48 PM   #5
Ares5
Drives: Yaris I
Old 01-23-2022, 12:53 PM   #6
TerrorByte
Drives: Yaris 2010 1.0 gpl
Hi, i have the same problem, how did you resolve?
TerrorByte is offline   Reply With Quote
Yaris 2004 Dashboard problem HappinessConsultant General Yaris / Vitz Discussion 5 10-17-2017 01:51 PM
My "passenger air bag ON" lights turns off when headlights turn on? Henry_mak16 DIY / Maintenance / Service 1 06-19-2013 04:37 PM
Anyone bought these angel eyes headlights from Depot lights? YAR1S General Yaris / Vitz Discussion 8 02-04-2012 01:54 PM
Changing dashboard lights gm830 Cosmetic Modifications (Exterior/Interior) 5 02-01-2012 12:00 AM
interior lighting problem tied with headlights 40oz DIY / Maintenance / Service 7 03-28-2010 08:52 PM
