Old 01-16-2022, 10:52 PM   #1
xdarkxfirex
Drives: 2015 yaris le
Scratches on engine after installing belt
I've installed a belt on a 2015 Yaris and have some superficial scratches from prying. I've installed and removed this belt and tensioned it when the car was bought 5 years ago. It still didn't look too bad but I had a Bando ones I ordered a few years ago but didn't install, till today.
I have some scratches on the block and head, some under that coolant plug with the Allen head. Don't know it's name, but I was a little worried since it looks thin. Not really visible on camera. I didn't pry hard enough to break anything. But finally figured out the right spot after not doing it for years.
xdarkxfirex is offline   Reply With Quote
Old 01-19-2022, 08:54 PM   #2
Cletus Garfunkle
Average KKT User
Cletus Garfunkle's Avatar
Drives: 2001 Echo
That should be just fine that allen head is a filter for the VVTI solenoid. You should not have a single problem there is way more than enough metal there you arent gonna hurt a thing with some small scratches like that.
Cletus Garfunkle is offline   Reply With Quote
Old 01-20-2022, 07:33 PM   #3
xdarkxfirex
I used to have an older Yaris with the same setup minus the AC compressor. This one was giving me a harder time with moving the alternator. The place I worried about was where that hollow tube is. Right under I had some scratches but not too bad
My main concern was that if there were any micro cracking that could get worse
Tags
2015, belt, serpentine
Zage Turbo Kit Install - Toyota Yaris Focus_Sh1ft Forced Induction Forum 160 02-06-2022 09:14 PM
Oil change shop says alternator belt is cracked RMcG DIY / Maintenance / Service 19 05-02-2018 08:38 AM
***The Engine Oil Bible*** Hussain-Vtec Performance Modifications 20 09-28-2016 03:47 PM
1ND-TV engine swap Daox Fuel Economy Forum 11 10-01-2015 03:49 PM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
