Old 05-11-2017, 11:55 PM   #1
KSIbucky
KSIbucky's Avatar
Drives: 2007 Yaris manual dark silver
Send a message via AIM to KSIbucky Send a message via MSN to KSIbucky
07 yaris wont start
Went to start my yaris yesterday and it wouldnt start no click nothing. Radio comes on all lights work. Battery is charged even tried using a new battery. Took the starter to oreillys and have it bench tested. Oreillys said its good. I'm going to take it to another place to have it tested tomorrow. We pop started it today and it drove fine. 07 5 speed.
7 Color Tach
Fujita Intake
Momo pedals Shift knob and boot. Full TRD SSK.
Blitz exhaust
Megan Lowering Springs
(Next is DC Header)
KSIbucky is offline   Reply With Quote
Old 05-12-2017, 05:20 AM   #2
DiCaprio
Just a Gaijin
DiCaprio's Avatar
Drives: 2006 Yaris 4 door 1.3l
Check out this thread: http://www.yarisworld.com/forums/showthread.php?t=58254
There is a lot of useful Information
DiCaprio is offline   Reply With Quote
Old 05-12-2017, 06:37 AM   #3
alias06
Drives: 2008 Red Toyota Yaris
sounds like you should check the neutral safety switch
alias06 is offline   Reply With Quote
Old 05-12-2017, 09:53 AM   #4
KSIbucky
KSIbucky's Avatar
Hiw can i test the neutral saftey switch.
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 05-12-2017, 09:58 AM   #5
its under the clutch pedal at the firewall
Old 05-12-2017, 10:46 AM   #6
KSIbucky
KSIbucky's Avatar
I know where it is. How do i test if its bad?
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 05-12-2017, 08:44 PM   #7
ex-x-fire
Get a test light, hook the end up to ground & see if you have voltage on both sides of the switch as you push on the clutch pedal.
Old 05-13-2017, 09:44 AM   #8
Bluevitz-rs
Bluevitz-rs's Avatar
Drives: '05 6-Spd Vitz RS
You can push the switch with your finger as you turn the key to the start position to test it also. Just make sure you're in neutral. Sometimes floor mats get in the way an don't let the clutch push down far enough. That happens on my Mother's Matrix XRS sometimes.
Unplug the switch and jump it with a paperclip if the switch is bad.
Old 05-15-2017, 11:51 PM   #9
KSIbucky
KSIbucky's Avatar
Not the neutral switch. Changed thw starter whats next. Remeber i can get it running by pop starting it.
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 05-16-2017, 12:39 AM   #10
Bluevitz-rs
Why did you change the starter? Wasting money isn't going to solve the issue.
Test all the systems that have to do with the starting circuit before you go wasting money on a guess.
Old 05-16-2017, 09:47 AM   #11
David C
Drives: White '07 3dr LB
Starter relay fuse is all good too ? Really sound like a wiring issue.
David C is offline   Reply With Quote
Old 05-16-2017, 09:30 PM   #12
SirDigby
Drives: 2007 yaris 3 door
wait!!! if you can pop start it, then you have a standard transaxle. NSS is on an automatic transaxle. you do not have a NSS. you can get the starter tested before replacement.
did you test the resistance in the clutch switch? did you check the resistance in the start position on the ignition switch? did you test your battery?
Old 05-22-2017, 12:10 AM   #13
KSIbucky
KSIbucky's Avatar
David called it. Two fuses out. I dont understand how they went out but its fixed now. Fyi new starter was returned. I work in a shp with easy access to parts.
7 Color Tach
Fujita Intake
Blitz exhaust
(Next is DC Header)
Old 05-22-2017, 01:10 PM   #14
David C
Lucky guess from an electrician ;)
Old 04-06-2020, 05:29 PM   #15
Pinchlite
Drives: 2007 yaris HB
It would help if you mentioned what fuses were bad.It would help others in the future.
Pinchlite is offline   Reply With Quote
Old 01-11-2022, 10:16 PM   #16
Hiro
Drives: 2007 Hatchback Auto
Similar issue here
I think I have checked all of my fuses under steering wheel and in engine compartment. Where is the starter Relay?
Hiro is offline   Reply With Quote
Old 01-11-2022, 10:17 PM   #17
Hiro
Starter relay?
I am thinking I have a similar issue, am going to test the relays just get overwhelmed by electrical diagnostics. Youtube has some good videos am watching.
Old 01-22-2022, 03:08 AM   #18
Hiro
Turns out it was my shift lever not going all the way into position.
Hard start in the morning 2008 Yaris CE volks_r_us DIY / Maintenance / Service 9 03-09-2018 04:18 PM
Do you like the 2012 restyle? hitmoninfinity Third Gen Yaris General Discussion 106 04-14-2016 09:08 PM
2007 yaris instrument cluster dead and engine won't start dchippowski DIY / Maintenance / Service 2 05-17-2015 12:00 PM
2008 Toyota Yaris Hatchback Wouldn't Start kieranhiggins DIY / Maintenance / Service 2 05-12-2015 09:18 PM
