Old 01-23-2022, 05:29 PM   #1
sh0rtlife
engine rattle noise NOT the exhaust shield
so basically since the car was new its had an odd rattle, sometimes its worse than others, but its officially annoying as hell and on my sh!t list to fix
its tinny and rattly and i assumed it was a heat shield but nothings loose
today i went out with a nice chunk of sound deadner and covered over the exhaust, no change, covered the intake side, minimal change, covered the front timing cover area and whoa sound almost gone, so its deffinatly front side noise, im going to pull the belt and see if noise changes
so..whats the deal?...the car has about 160k on the clock..kilometers not miles, and is a 07 canadian 5dr
it does seem to "fade" a bit when warm and in the summer, its way worse in the winter months
Old 01-23-2022, 09:13 PM   #2
ex-x-fire
Are you using the correct oil weight?
Old 01-24-2022, 12:18 AM   #3
sh0rtlife
originaly it was changed via dealer untill the warrenty was up, i personaly have been changing it the past 10 years, its been doing it since probably a year after it was new, i even switched over to synthetic hoping maybe that might effect it for better or worse..no change
Old 01-24-2022, 04:54 PM   #4
xdarkxfirex
Drives: 2015 yaris le
I had a problem like this on my older Yaris. The exhaust donut gasket was making a weird rattle everytime you would shift gears, or it would move. Its the flange ahead of the converter. Might be your issue
xdarkxfirex is offline   Reply With Quote
Old 01-30-2022, 12:32 AM   #5
sh0rtlife
heck its worth checking if nothing else
Old 01-30-2022, 07:26 AM   #6
CB900F2
Drives: 08 Sedan
Might be the joint between the exhaust header and pipe, the donut gasket over time compresses and then the pipe and manifold rattle... I had to replace it once already on my yaris, like about 7 years ago, (mine is a 2008), and now its doing it again.. Will replace it this summer..
You can search this site for threads on this issue..
CB900F2 is offline   Reply With Quote
exhaust manifold heat shield (noise) rayfloyd170 General Yaris / Vitz Discussion 7 09-27-2021 02:54 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
Exhaust rattle (not a heat shield) Em_ DIY / Maintenance / Service 7 04-23-2013 09:48 PM
Exhaust heat shield.... vital? Beer Jammer DIY / Maintenance / Service 1 09-17-2010 10:52 AM
rear exhaust heat shield Toy Yaris DIY / Maintenance / Service 7 04-19-2010 07:03 AM
