![]() ![]() Drives: 2015 yaris le Join Date: Feb 2015
Coolant filler neck
How often do these need replacement? Alot of times my arm is leaning beside it flexing it a little but nothing is leaking. I spray rubber protectant on it and plastic parts under the hood every once in a while
![]() ![]() ![]() Drives: 2007 Toyota Yaris 3 door Join Date: Sep 2018
you can get an aftermarket metal one, or just replace it and get that weight off your chest, they will break eventually.
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
I have an aluminum one on my car that I got from Aliexpress, it cost under 30 bucks and is actually good quality. Just be careful when working around it if the engine is hot as the aluminum holds a lot of heat(way more than the plastic one) and will burn your arm, I know from experience.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
For me personally I would rather keep one extra so when I replace the coolant next it's there. The one I got from AliExpress was like $19 cad with shipping and 5 star reviews.
Hopefully I won't have to do the water pump on this car like the old yaris I only ever recall seeing one break on a friend's 2010 RAV4. I believe the ones with the tiny hose outlets are easier to break |
#5 | |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 12:56 PM |
| What is a (or the) coorect coolant & amount for a Yaris? | RMcG | DIY / Maintenance / Service | 0 | 06-19-2019 06:36 PM |
| Removal of petrol filler neck and wheel arch welding | SilverChariot | DIY / Maintenance / Service | 1 | 06-18-2017 08:44 AM |
| Coolant Level in filler neck? | CB900F2 | DIY / Maintenance / Service | 26 | 05-18-2014 06:09 AM |
| toyota yaris sedan, missing flap just inside fuel filler neck | 41magmag41 | General Yaris / Vitz Discussion | 3 | 10-17-2010 05:43 PM |
