Old 03-10-2023, 03:30 PM   #1
santy_sanchez1989
Drives: yaris
Wiring Diagramfor 2018 yaris
Hi! I´m from Argentina. I have a 2018 Yaris manual transmision. If someone have the Cruise Control wire diagram, Because I made the connection for the cruise control, it turns on but does not "SET". And I don't know if I'm missing some cable in the ECU for the clutch or what. Thank you
santy_sanchez1989 is offline   Reply With Quote
Old 03-12-2023, 03:35 AM   #2
kevinj93
kevinj93's Avatar
Drives: 2013 NCP130
Search the site for "cruise control". There is a switch required for manual transmissions.
The switch mounts on the clutch pedal bracket. Its purpose is to cancel the cruise control when you push the clutch pedal. The connecting wires should already be in the wiring harness, but are most likely taped up inside it.
Running on standard AU 14" steel wheels (14x5 rims, 175/70R14 tyres). Added reversing camera and touch screen radio, cruise control, 16" rear wiper blade, tow bar and dash cam.
kevinj93 is offline   Reply With Quote
cruise control
Remote Start DIY Wiring Guide 2006-2010 Yaris CTScott DIY / Maintenance / Service 272 01-22-2022 11:02 PM
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 12:56 PM
Need Toyota Yaris 2003 tail or backlight wiring schematic Martintim In Car Entertainment + Electronics (audio / video / alarm) 0 08-22-2016 11:35 AM
99 Yaris alarm wiring Povo In Car Entertainment + Electronics (audio / video / alarm) 0 08-03-2012 05:47 AM
