Old 10-27-2021, 02:04 AM   #1
CrimsonEclipse
Drives: .
Lower Control Arm ball joint bolt seized
Trying to replace the lower control arms on a 2011 Yaris.
The bolt that attaches the control arm to the bearing assembly (locked with a cotter pin (which was removed)) spins without loosening. I placed a jack under the ball joint and added pressure but it wasn't enough.
Can I use a pair of vice grips through the ball joint boot and clamp down long enough to break the threads loose
Note, I am using thread oil to possible loosen up the threads
I am replacing the lower control arms because the rubber around the rear bolt is cracking and possibly failing.
CrimsonEclipse is offline   Reply With Quote
Old 10-27-2021, 08:10 AM   #2
ex-x-fire
They can be tough, the ball joint stud is usually held tight in the knuckle while you unthread the nut. I'd soak it for a while, if you have a torch then you can heat the nut up.
Old 10-28-2021, 04:51 AM   #3
CrimsonEclipse
Drives: .
Used a vice grip. Destroyed the boot in the process.
Now the forward bolt hits the engine block and can't be removed.
Oh, Toyota, you so crazy.
Old 03-23-2023, 04:51 PM   #4
JustFPV
Drives: 2006 Yaris 2dr hb manual
just had to cut mine off with a torch. The bolts for the lower control arms are terrible and I ended up putting new arms on with bolts for a mercedes clk230 (perfect fit/length and same thread). Its a very common issue with these bolts being a bad design from toyota so replace them asap especially with higher mileage
JustFPV is offline   Reply With Quote
Ball Joint Warning tmontague Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 03-31-2024 09:39 AM
DIY - 2009 Cruise Control for $10, without pulling the steering wheel and airbag CTScott DIY / Maintenance / Service 307 04-04-2023 04:43 AM
Warning - Broken control arm bolt! CB900F2 DIY / Maintenance / Service 460 08-23-2020 06:54 PM
2007 hatch front passenger ball joint Phatdonkey78 DIY / Maintenance / Service 4 02-16-2019 12:56 PM
Ball Joint on Bottom Arm David Godfrey DIY / Maintenance / Service 1 04-18-2010 07:27 PM
