01-23-2023, 07:13 PM | #1 |
Drives: 1987 Silverado Join Date: Jan 2010
How much should I pay to have the water pump replaced?
Hi all. My 2009 Yaris is making some kind of engine noise. Almost like a soft, clattering clacking noise. Still loud enough to be embarrassing. The noise increases as the engine revs. I took it to the dealership to get their diagnostic, they said they believe it's the water pump. And they said that the pump is leaking. I did not notice a puddle, nor has the low coolant light come on.
Still they're probably right and the pump is making the sound. How much should I pay a reasonable mechanic to replace the water pump? I'm assuming $900 is exponentially higher than the job is actually worth, in typical dealership fashion. Would say... $300 be closer to the mark? |
01-23-2023, 07:29 PM | #2 |
Drives: 2010 yaris 3 door hatch Join Date: Jun 2013
It's not a difficult job. Why not replace it yourself. Anyways $900 sounds like a lot. $300-400 is more reasonable.
01-23-2023, 08:56 PM | #3 |
Drives: 2009 Base Hatch 2 Dr Auto Join Date: Dec 2008
$300 did my wife’s Camry a few years agp
01-29-2023, 02:26 AM | #4 | |
Anybody know how to pronounce that? Aisin. |
01-29-2023, 08:18 AM | #5 |
I'd say it like Asian with a lisp.
01-29-2023, 06:32 PM | #6 |
Drives: 2007 4dr sedan Join Date: Jun 2009
01-30-2023, 07:54 AM | #7 |
03-22-2023, 07:48 PM | #8 |
Finally got time to install the pump. It's one of the easier automotive repairs I've done. I'd recommend it to anyone who has turned a wrench or two in their day.
But it appears I have a squeal now. Surely that couldn't be the new pump... What would cause an intermittent squeal to appear after changing the pump? Maybe the belt? |
03-22-2023, 07:52 PM | #9 |
Drives: 2007 5dr canadian import Join Date: Dec 2016
yeah its one of the simplest waterpumps to be fair the only one coming to mind is early chevy 350 with its similar "cartridge" style pump
03-22-2023, 07:55 PM | #10 | |
03-23-2023, 10:05 AM | #11 |
yup loose belt, you need to "pull" the alternator away from the engine block to put the belt tight, typical method is to "pry with one hand and tighten the alternator with the other, but you need to be mindfull of your pry tool and location as theres a sensor in that area
03-28-2023, 04:34 AM | #12 | |
04-05-2023, 11:24 AM | #13 |
would greatly depend on bar length vs arm strength LOL....ive been setting belts like this since 91 so my in arm calibration for this is kinda set in stone
tho a couple rooky mistakes to be mindfull of pry bar position ...be mindfull of whats back there and where on the alt your putting pressure...ive cracked some over the years ALWAYS tighten the "big" bolt first...in the yaris case thats the bottom one....doing it small first will typicaly lose you some of your adjustment due to flex and result in noise tightness on a "fix belt" system be is V belt or serp..tighten it like you would a tie down..your looking for very tight but not silly...most ppl unless they have alot of force cant get to silly if they tryed this ones yairs specific..cold..ice bloody cold...first thing in the morning cold is the ideal time to adjust the belt ...as this will be when it wants to make the most noise as all the parts have "shrank" due to temps.....more than a few times i did it mid day or with the engine warm only to have morning squeal |
04-07-2023, 04:19 PM | #14 |
Drives: 2009 yaris 2 door Join Date: Feb 2013
manually tighten belt
That's how belts were tightened back in the seventies when i was a teen. it's a matter of feel and experience, don't overtighten or it'll ruin the belt or shorten the lifespan of the alternator bearings. after you tighten push on the belt in the middle section between the water pump and the alternator and it should flex a little.
Thread Tools | |
Display Modes | |
Similar Threads | ||||
Water or Water/Methanol Injection DIY | 06YarisRS | Forced Induction Forum | 41 | 06-20-2020 02:03 AM |
Yaris leaking water pump | SeattleCommuter | DIY / Maintenance / Service | 10 | 05-16-2015 09:03 PM |
Rear Shocks Replacement? Water Pump. | babytic | DIY / Maintenance / Service | 7 | 06-15-2013 03:55 PM |
GROUP BUY - JDM (RS) Vitz LED Tail Lamp ... | riceboy | Items for Sale by private party | 453 | 07-14-2007 08:30 AM |
