![]() Drives: yaris Join Date: Nov 2018
Shifter cable bushings
Just finished my final mod for my shifter and the bushings make a world of difference. I already have the solid bushings on the shifter assembly and a short shifter but these bushings were the final touch it needed and I highly recommend it to anyone with a manual.
The stock bushings will give you hell and you will probably need to dremel them off but its well worth the end results. |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
I was able to pop mine off with just some thumb force. But yes I agree, these bushings coupled with my TRD quick shift assembly from Japan and weighted shift knob make a world of difference. Now I need to address the shit garbage stock 3.72FD in the transmission and replace it with a 4.31FD + C59 5th gear
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's
#3 | |
The 6th gear is the same as your 5th anyway so you don't benefit from lower rpms, is the C59 fifth gear taller? If so what you mentioned sounds like the perfect solution to the 5 speed, shorter 1st and maybe even 2nd gear but have a taller 5th gear to reduce highway rpms. |
#4 | |
Gen 3 > Gen 2
C50 5th gear is 0.815:1 With the 4.31 final drive, the longer C59 5th gear drops the cruising RPM to around where the stock 3.72 would be at with the 0.815 5th gear, give or take a couple hundred rpm. Extra shifting doesn't bother me, I love driving stick, every aspect of it. Its just muscle memory at this point lol
| Shifter cage bushings? | Caramanos2000 | Performance Modifications | 6 | 12-05-2014 07:59 PM |
| The MI SSK "Not a Big 'Car Guy'" Review | jpmck03 | Performance Modifications | 36 | 09-20-2013 12:41 AM |
| TRD SSK & Shift Cable Bushings Issue/Question | minnyar | Performance Modifications | 5 | 04-14-2010 11:50 PM |
| Bronzoil Cable Bushings for the Yaris/Echo now available! | TWM Performance | TWM Performance | 58 | 03-31-2010 11:19 AM |
| NST shifter cable bushing users: Lube up! | schleppy | Performance Modifications | 11 | 07-05-2009 09:47 PM |
