![]() Drives: 07 Yaris Sedan Join Date: Apr 2010
2007 Yaris Sedan: No start or click, green temp light flashing
Need some help! I can't figure out what is going here. I have a 2007 Sedan that was operating just fine. Went to a doctor's appt, came out to leave and didn't start. No cranking, no clicking... nothing.
![]() Also, when I attempt to start it. The green temperature/coolant light starts flashing. I don't think I've ever seen it do that before (even when the car didn't start). The light will remain flashing even after I move the key to the off position and remove it. Only was I can get it to stop flashing is to shift into a R/N/orD and then back to park. Which I should mention.. the steering wheel isn't locking when the key is out and I can work the shifter (Automatic). All electronics in the car work perfectly fine. Battery is fully charged. Starter was replaced about 3 months ago... Thermostat was replaced near the same time. Car had been overheating, but the problem was fixed. Thinking the green temperature light flashing might mean low coolant level [preventing the car from starting], I checked the coolant. It is full. Checked all the fuses under the hood, nothing is blown. There's 12.5 volts at the starter. I removed the starter relay and tried to bridge it with a wire to "jump" the starter... no luck. I had an aftermarket (Avital 5305L) alarm/remote start in the car, but have since removed it thinking it may be some starter kill feature gone haywire. Any thoughts?? I can't help but think it has to do something with that green temp light flashing.. but after searching, I can't figure out what that means. |
FYI, it all turned out to be a grounding issue.
| Tags |
| dead car, not starting, start |
| 2007 Yaris Sedan part out | JumpmanYaris | Items for Sale by private party | 61 | 07-05-2015 02:57 PM |
| Toyota Yaris 2007 car wont crank no start | aamrkhan | DIY / Maintenance / Service | 0 | 01-19-2015 11:31 AM |
| Yaris 2007 Sedan in Canada | David81 | New YARIS Purchase Forum | 16 | 09-09-2007 03:09 PM |
