Old 09-25-2023, 02:11 PM   #1
Jimbo107
Drives: 2007 Yaris
2007 Yaris Maintenance Question
Hey, I have a 2007 Yaris I bought new . All I have ever done is oil changes, new tires and new batteries a few times. Still has original everything including brakes. Best bargain I’ve ever had in a car.
I’m up to 130,000 miles and car still runs perfect. My question is should I bother changing any of the other fluids ?( Transmission, brake, differential , etc. ) or just leave well enough alone?
Jimbo107 is offline   Reply With Quote
Old 09-26-2023, 08:09 AM   #2
spottynatty
Drives: 2007 Yaris 5-Door
You should definitely look to replace the brake fluid. Unfortunately if you leave it too long it can rust the bore of the master cylinder causing leaks.
The coolant is probably also due and it wouldn't hurt to change the transmission fluid.
What about spark plugs, engine air filter and cabin air filter?
spottynatty is offline   Reply With Quote
Old 10-02-2023, 07:39 PM   #3
Billiam
Drives: '10 White Yaris 4D LB
I would change all of them. Personally I have had good success with Valvoline Zerex Pink Asian coolant, Valvoline brake fluid DOT 3/4 and Valvoline Maxlife ATF. Our Yaris has lived a long life on these fluids.
On a side note....I use Valvoline Maxlife synthetic 5w30 oil as well.
If you want to enjoy your car, stay off of the internet.
Old 10-09-2023, 06:12 PM   #4
sh0rtlife
DO NOT change the trans fluid unless it smells burnt or is dark....
Old 10-11-2023, 06:38 AM   #5
Billiam
Changing the ATF will hurt nothing. 2 or 3 simple drain and fills can benefit the transmission. What's generally not the best idea is to flush a transmission with higher mileage.
Old 10-11-2023, 08:09 AM   #6
ex-x-fire
Yeah, by then it's too late.
Old 10-11-2023, 09:09 PM   #7
Billiam
With a flush you risk dislodging debris that could clog up the valve body. That's why drain and fills are the way to go on an older high mileage transmission
Getting ready to buy a 2007 Yaris hatch Type456 New YARIS Purchase Forum 26 02-17-2014 12:48 AM
