![]() ![]() Drives: 2007 Yaris hatch Join Date: Jun 2017
Tein S Tech with Tokico Blue or Tein Street Advance Z coilovers
I'm trying to decide between the Tein S Tech springs and Tokico Blue struts & shocks or just getting the Tein Street Advance Z coilovers for my 2007 hatch. The price is basically the same.
The coilovers seem like a cool option, but I wonder if the added bonus of being able to adjust ride height, etc., can also become a hindrance because of the added complexity. The S Techs and Tokico setup would be plug and play which is cool. Does anyone know how the two setups compare? |
![]() ![]() ![]() Drives: Twin-charged rotary V8 w/nos Join Date: Nov 2011
Go for the coilovers.
lol. |
I went the cheaper route and started with the Tein S Tech springs, paired with factory shocks/struts. Once the factory shocks/struts go, my plan is to replace with Bilstein B8's.
I'm not a mechanic by any stretch of the imagination, but my understanding is the lower level Tein coil overs can't be rebuilt like many higher end coil overs can be. Additionally, with our car's rear suspension design, it's not really a coil over, it's still a spring/shock combo. Lastly, I've heard the opinion of several more knowledgeable folks than I, that claimed a proper spring/shock pairing can provide one of the best street setups you can have, so long as you don't need all the adjustments you get with coil overs for track days. That's just my 2 cents, which is probably really only worth about 1.5, so take it for what it's worth
#4 | |
I noticed what you are referring to regarding the rear being spring and shock (though adjustable). I am not even sure I'll be making adjustments much. How are you finding the ride with the stock shocks/struts? |
#5 | |
My issue is that with 17" wheels and the aggressive drop of the Tein springs, I rub a little when hitting those really big freeway hips. It's rare, but does happen. I suspect that maybe stiffer shocks/struts, like the Tokico or Bilstein, would solve for it at the cost of a little comfort. |
#6 | |
I plan on sticking to 15's, so hope that rubbing won't be a factor. Are you rubbing the actual fender or liners? |
Fwiw to add to the discussion I am currently running MicroImage lowering springs with tokiko blues rear and KYB excel G oem up front. I find the front severly lacks the stiffness to handle the springs. I live around really rough roads and this is where I find the issue comes out. On relatively smooth roads they are fine. If you are doing any hard driving and want more performance then the Bilstein b8's will be a good choice.
I'd ecommend the coil overs only if you need the adjustment, if not then springs and a quality shock/strut will do the job well. This upcoming spring I'm finally going to coil overs and selling my current set up as I need something more for the track, for DD'ing it was fine
i had tokico blues with the microimage first batch (AOE) of springs. They were indeed too soft on the front, but overall handling feel is great.
i since switched to coilovers and the car is much more stable, with higher grip, but to me handling feel has dimished somewhat. I think tokico stopped production of yaris kits, and what you're buying is leftover warehouse stock. |
#9 | |
What would be the problem with putting together a set from leftover stock? |
Handling feel is feedback given to you when driving, giving a sense of what each corner is doing at any given time. The strut spring combo gave that feedback, but i felt that its cornering limits are low.
The problem with leftover stock is getting replacements can end up being a problem. I think they have a lifetime warranty, but will it honored, or is there any stock left to cover it? |
#11 | |
Leftover stock: I didn't think of that and its a good point. For me its probably not a big factor unless I ended up with a defective shock/strut or I got a premature failure, because I don't log a lot of miles per year (~ 6K or less per year), but you're right, that is a consideration because they won't have a replacement shock/strut available if one happens to crap out, so I'd have to replace all four again. |
![]() Drives: 08 Yaris D4D, Supra, VW Camper Join Date: Jan 2018
After finding some new Tein lowering springs on ebay i was toying with going with springs for now on standard shocks. with the 16 inch wheel and 195 40 16 tires i was looking at i figured i was safe with just springs for now. especially as they were so cheap!
Small cars are a big deal
Drives: 2007 Yaris Liftback Join Date: Feb 2006
I had crappy Megan coilovers for about 14 months. They rode hard and rusted. I swapped them out for S-Techs and HPs and couldn't be happier. It's a much better street setup that actually absorbs bumps and allows for some travel.
Unfortunately, I understand Tokico doesn't make the HPs for the Yaris anymore.
Subcompact Culture: The Small car blog |
#14 | |
One more question. Would the rear Tokico blues for a Scion XD work on the yaris?
Nevermind, wouldn't want to Frankenstein it anyway. I've called around and even though online retailers are showing the rear shocks as available, they in fact are NOT in stock. Tokico Blue for the Yaris is no longer an option. ____ update _____ Since the Tokico's are not available and the TRD's are overpriced IMO, I just ordered a set of Tein Street Advance Z coilovers. Will post some pics when they arrive. Last edited by Type-Y; 01-17-2018 at 05:37 PM. |
The Tein coilover setup arrived today. Amazing, since I just ordered it yesterday. The box is heavy and so are the struts themselves. The finish is very nice. They have the overall feeling of quality. Here are some photos:
going to reuse your bits or buy new rubbers/hats/bearings for assembly?
| Tokico blue or ksport coilovers? | Caramanos2000 | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 6 | 03-11-2016 09:35 AM |
| FS: Tein S-Tech Lowering Springs / Tokico Blue Struts & Shocks | DPS | Items for Sale by private party | 18 | 10-09-2014 10:35 PM |
| FS: Tein S-Tech Lowering Springs / Tokico Blue Struts & Shocks | Freestylin | Items for Sale by private party | 21 | 02-04-2014 07:33 PM |
| TEIN - Basic Coilovers *Now Available* | EnduroMTS | Sponsors Classifieds Area | 4 | 10-13-2006 02:43 PM |
| TEIN Basic coilovers | C2AUTOSPL | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 15 | 06-26-2006 01:57 AM |
