Old 04-07-2016, 02:54 PM   #1
Javier_vios
Drives: Toyota Vios Yaris
Thumbs up All New Yaris Latino America Cruise Control
Hello,
Anybody can helpme to understand the wiring of this model?? This is a drive by wire 1nz fe, also know as Third generation Vios.
http://s2.paultan.org/image/2015/01/...0717440659.jpg
My guest is pin 40 of conector A21 as always.
Best Regards
Javier
Javier_vios is offline   Reply With Quote
Old 04-08-2016, 09:04 AM   #2
Javier_vios
This car is being sell in Latino America as a Toyota Yaris
Old 04-08-2016, 07:46 PM   #3
From what I have read about the 3rd gen Vios cruise control is not even an option, which likely means that the ECM is not programmed for it.
You can check the steering column connector for presence of the wires for it and if they are present, then perhaps it does.
Old 04-08-2016, 09:45 PM   #4
Javier_vios
I know for fact that is not just de cruise control switch because I try the just switch and didn`t work. I did not check the spiral wiring to the DL3 conector and didn`t check the wiring from the DL3 conector to the ECU (pin 40).
If were a programing problem... Is there any solution? Or I need to go with an aftermarket cruise control ??
Best Regards
Javier
Old 04-08-2016, 10:09 PM   #5
Best Regards
Javier
I don't have the wiring diagrams for the Vios, so I can't tell for sure. Does the ECM look like the 06-11 ones (which have the connector with the pin 40 shown in the DIY) or does the ECM look different than that?
Old 04-09-2016, 08:39 PM   #6
Javier_vios
I just have the model, later I´m gonna try to remove the "bag" to see the ecu.
I still can`t figure out how to remove it
Old 04-09-2016, 08:51 PM   #7
That's the AC ECU.
Old 04-20-2016, 07:32 PM   #8
Javier_vios
CTScott,
Here is the Engine Control unit, is not the shape that i did hope.
Best regards
Javier
Old 05-04-2016, 08:50 PM   #9
Javier_vios
Anyboby any help ???
Old 08-08-2017, 02:06 AM   #10
laobo
Drives: yaris sedan 2011
CTScott,
Best regards
Javier
I think you try pin 18 of top connecter which first top. Dear
laobo is offline   Reply With Quote
Old 05-04-2016, 09:14 PM   #11
As I said above, cruise control is not available on the 3rd gen Vios.
Old 05-04-2016, 09:17 PM   #12
Javier_vios
Ok, thanks ...
Old 05-04-2016, 10:03 PM   #13
jcboy
Drives: Sedan 07
surprised to see your ecm is made in the philippines. probably in the Sta Rosa Laguna plant. well i wouldnt be surprised one bit that Scott is right, for one, he is right 99% of the time, and two, Vioses in the Philippines don't have cruise control even as an option.
Old 05-05-2016, 08:10 PM   #14
Javier_vios
Hello,
I see that cruise control is not even an optional in Vios/Yaris, but the steering wheel came with a cover to remove for a cruise control switch, that`s why I belived that is was posible conecting the ecm in the correct pin...
If is not posibile just conecting the switch to ecm, Is another solution ?? A toyota module ??? An after market cruise control ?? Another ecm ??
Thank you both for your answers... by the way this yaris is made in Thailand.
Best Regards
Javier
Old 05-06-2016, 08:21 PM   #15
Hello,
Best Regards
Javier
Toyota uses many of the same parts on cars, even if the feature is not present. Also, that cover is the only way to access the release tab for the airbag on that side of the steering wheel.
Old 05-07-2016, 12:15 AM   #16
jcboy
Drives: Sedan 07
Hello,
Best Regards
Javier
I've been dreaming and been envious of the Cruise Control discussion in this forum for a while now. Very useful especially when using Superhighways, where the stretch is at least 75km long but top speed is limited to 100km/h.
Cool, some of my Yaris parts are made in Thailand actually, i've seen Made in Japan too in some them (IIRC).
This is our steering wheel and if this is the same, then Scott is correct, it's only an access door for the release tabs. (to remove SW)
Old 06-11-2016, 08:49 PM   #17
Javier_vios
Hello,
This is my toyota steering wheel, I`m still hoping solution, I know that this ECM is not the one that have cruise control in pin 40 of conector 21, but the ECM of 4 row and 4 conector could have cruise control programing in pin 21 of the conector with 31 pins as in toyota hilux ...
Any comments ??
Best regards
Javier
Old 06-12-2016, 03:28 PM   #18
Javier_vios
I did try with 21 pin and 30 pin ... no luck yet.
Cruise Control - Again! CB900F2 DIY / Maintenance / Service 47 06-17-2010 06:29 PM
