Old 08-23-2010, 12:32 PM   #1
Carly
Drives: Toyota Yaris
Exclamation Problem with my electrics cutting out - any idea why?
Hello!
I was wondering if anybody here has had the same problem, or might possibly know why my Yaris is behaving strangely!
Basically, today I drove a car load of stuff up the motorway (done this previously, fine) and as I'm overtaking all the electrics suddently cut out. The engine is still on but the radio goes off and the electronic dashboard goes off too (i.e. speedometer, petrol meter etc).
It happened a couple of times, just for a second or two and then it all comes back on.
A few different lights flash up, but then they go off. The ABS is always the first to flash up before they all go off. That one kept coming on, but the last few times it happened (with an empty car, going slower on the way home) all the lights flickered on and off. Braking also felt odd as if the ABS had conked out or something for a second or two.
I tried to check through the owner's manual and it did say something about electrics cutting out if the car overheats, but I'm not sure if it meant the whole car would cut out, not just the dashboard.
What do you think it could be??
Cheers :)
Carly is offline   Reply With Quote
Old 08-24-2010, 01:36 AM   #2
yarisugi
やりすぎだ~
yarisugi's Avatar
Drives: Me: Nuts:
Check your wire connection on the battery, both + and -. Also, check the other end of the - wire from battery. It should be connected to the body of the car. Something might be loose and may be why you have intermittent loss of power. You might want to check your fuses, too, just so nothing was shorted out.
Old 08-26-2010, 11:22 AM   #3
Carly
Thanks for your reply.
I called a mobile auto electrician who did a diagnostics test for me.
He couldn't find anything wrong, nor did the computer bring anything suspect up. He did say there was something all over the battery and he cleaned that for me. All wires and fuses were OK!
Then he noticed there was something missing off my engine and I then took it to another garage just now and on the engine something had popped off. I think he called it a blower or something! The coating around the wire was a bit melted, which explains the burning smell I smelt - but luckily it hadn't split so it still OK just to put back on!
All very random! Hopefully somewhere between those problems being fixed the electrics should be fine!
Old 02-10-2024, 08:11 AM   #4
Gazhat
Drives: Yaris D4D
I know this thread is 14 years old but did you find out what caused the issue? My 2008 Yaris is doing the same right now….
Gazhat is offline   Reply With Quote
Tags
abs, dashboard, electrics, toyota, yaris
Problem Starting Car drunkwithwords General Yaris / Vitz Discussion 3 07-21-2010 04:01 PM
Launching @ 4Krpm problem .... need tips Parmas Wheels, Tires and Suspension Forum sponsored by The Tire Rack 12 12-30-2009 08:11 PM
How can I get in touch with Toyota Regional Offices in Houston? woof DIY / Maintenance / Service 11 11-28-2009 09:29 PM
Yaris 06 H/B Engine Cutting out problem.. Farenheit General Yaris / Vitz Discussion 3 09-14-2007 01:21 PM
Service Problem Lizardboy DIY / Maintenance / Service 19 10-06-2006 09:12 PM
