![]() Drives: Yaris I Join Date: May 2018
Head light restoration
Hiiy
My yaris 2006 headlights are like this. This matter is in outside or inside. Any idea how to get rid of this. Can I try youtube sandpaper methods? Regards |
let me be clear, no headlight can be "permanently" restored
now thats not to say you cant get "some" improvement or even make them look new, but they will NEVER perform like new again....while you can get them to look nice, the plastic is damaged by UV and while you can sand, buff and polish them, it will always diminish the light output with that said, you can useualy "restore" a set of lights once without too much effort, id reccomend sanding starting at 220 dry then wet and working up to 2000grit, after that polish with your choice, tho i reach for rubbing and buffing compounds for paint, and work from course to fine...the end results will be stunning but will likely only last a year 2 and youll have atleast 2 full days into the lights all said..the amount of time and trouble it takes to do them, your almost always better off just buying new lights unless you have something genuinely special |
![]() ![]() ![]() Drives: 08 Yaris 3 Door Hatchback Join Date: Aug 2019
I've used aluminum wheel polish to remove the oxidation. However, it after a few months it goes back to being yellowish again, and I'd have to rebuff. No sanding required at least.
yup aluminum wheel compound does work well, at best youll get 6 months
going full out sanding will get you a year or more, now "if" you clear coat it with a quality UV automotive finish clear ive been told you can get 5-10 years, but the thing is, youll still have a "hazy" headlight...ive been tempted to try doing it on a brand new headlight to see how much longer life you could get, as then the clear coat takes the UV abuse not the headlight |
![]() ![]() Drives: 2007 Toyota Yaris Sedan Join Date: Feb 2019
Meguires plastX or ScratchX works well.
240 grit and then clear coat. I washed the plastic dust off then sprayed the clear too quickly and got a permanent white fog effect haha Sometimes if it ain't broke don't fix it is true |
#6 | |
I switched to just using the aluminum polish compound and it works just fine. I'm thinking of retro fitting a projector headlight, so I might buy new headlight to install them in. We'll see... https://www.yarisworld.com/forums/sh...ad.php?t=22124 |
240 isnt exactly too course..depends on how far gone they are, but stopping at 240 you may as well not do anything
i know when i did mine i had to start at 220 dry then 220 wet, followed by wet from there out 320, 400, 500, 600, 800, 1200, 2000, then a full polishing of 6 steps of meguires paint polish starting at course ending at fine...the results were STUNNING. and lasted about a year |
Just to revive an older thread:
For the past few years I've been trying to salvage the OE headlights on our '10 Liftback. Every 2 or 3 months I would buff them with some Plast-X. That would help but not last long. And increasingly it became difficult to even buff them out. So I gave up and ordered a set of Eagle Eyes from Rockauto. $110 and that included shipping and tax. No issues. They bolted up fine and adjust fine. Figured since I was replacing them I would throw in all new bulbs as well. Perfect for a 14 year old car with a 170k miles on it.
If you want to enjoy your car, stay off of the internet. |
Tags |
headlight restoration |
Thread Tools | |
Display Modes | |
DIY (08' USDM Liftback): ESUSE Fog Light Install v2.0 | goku87 | DIY / Maintenance / Service | 127 | 02-19-2023 07:01 PM |
Head Light Fade and flakes - Saudi Arabia | Omprakash | Middle East | 1 | 10-05-2015 03:05 PM |
Dealer: Disabling the seat belt chime is now illegal? | schleppy | Cosmetic Modifications (Exterior/Interior) | 13 | 04-18-2009 04:43 PM |
DIY:Day time running light Disabled with stock fog light remain function | summergxz | DIY / Maintenance / Service | 12 | 09-26-2007 10:42 AM |
Chrome door cover head light covers..? | jamal1984 | Cosmetic Modifications (Exterior/Interior) | 4 | 01-26-2007 03:19 PM |
