Old 04-07-2016, 09:31 AM   #1
ercdvs
Drives: 2010 Yaris
Exclamation Stupid Help? Why is this hose disconnected
been driving my new to me 2010 yaris for a couple weeks, decided to double check engine bay, oil, etc.
noticed this hose just... floating there. Nothing obvious that it connects to, and i can't see what its supposed to be to.
Anyone ?
ercdvs is offline   Reply With Quote
Old 04-07-2016, 09:52 AM   #2
That's the snorkel on the air intake box. It is not floating there. It is attached to the bottom of the black box you see beside it.
Old 04-07-2016, 09:58 AM   #3
ercdvs
Drives: 2010 Yaris
Yes the bottom is connected, but the top just floats there in space ?
i guess im just used to it connecting to the grill or some obvious way to funnel air vs just wiggling there in space
Old 04-07-2016, 10:05 AM   #4
Yes
Old 04-07-2016, 11:37 AM   #5
wildcard
wildcard's Avatar
Drives: 09 3dr HB 5sp
Thats where you put the NAWZ
wildcard is offline   Reply With Quote
Old 04-07-2016, 05:13 PM   #6
joell
joell's Avatar
Drives: 2013 Hatchback
As other users pointed, is part of the cleaner assembly that provides the engine the necesary air for the combustion.The shape is designed to conduct air to the lower part of the cleaner, the air is forced thru the filter and large rubber hose connects to the intake manifold if i am not wrong.
INLET, AIR CLEANER
17751-21160
joell is offline   Reply With Quote
Old 04-08-2016, 11:23 AM   #7
ercdvs
Drives: 2010 Yaris
right, on the subaru i traded in, the top part of this hose would have been connected to a portion of the front grille, to make sure air was being fed into the system.
It was just a little odd to see the top potion of the hose just floating free in space. Seems like having it face the grill would be better, but there is really very little need to have air forced into the system. Except maybe to make sure it was clean, cold air.
Old 11-14-2024, 01:30 AM   #8
rayfloyd170
Drives: Yaris 2016 1.3 Manual
My air inlet resonator falls off while driving aggressively at 150kph and my yaris sounded like a sports car esp when i flat it out. I temporarily used 2 pcs of pvc elbow to make that u bend and it sounded like the stock air inlet resonator. I already ordered the original part 17751-0M070 and will be here in couple of days.
rayfloyd170 is offline   Reply With Quote
HVAC dripping water when AC on. Drain hose is NOT clogged. kustomrtr DIY / Maintenance / Service 3 09-07-2014 10:45 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
vacuum hose / heater hose size cali yaris Performance Modifications 12 05-17-2013 10:58 PM
Hose for windshield wiper broke HDS DIY / Maintenance / Service 1 04-06-2012 11:26 AM
