Old 04-18-2012, 04:23 AM   #1
Paul Evans
Drives: Yaris SR 1.33
OEM tweeter wiring on UK Yaris
Hi Guys.
This is a bit of a long shot, but I'll ask anyway. I live in the UK and have a 2009 model Yaris SR, which has inbuilt tweeters and airbags in the A pillar.
I don't think US-spec models have OEM tweeters, but I know some other markets do, not just the UK.
I am thinking of replacing the headunit and the front door speakers and tweeters (with component speakers). Lots of threads on these forums about replacing headunits and door speakers, but I can find nothing about replacing the OEM tweeters. If possible I would like to put my new tweeters behind the existing grilles for a stealth look. However, reading the Yaris manual I am nervous of messing with the A pillars since there are airbags there. There is nothing in the Yaris manuals or wiring diagrams which explains how the OEM tweeters are wired, or how they can be accessed.
So - anyone done this? Is it possible to get the tweeter grills and/or tweeters off the A pillars without removing the entire A pillar inside trim? If I take the A pillar trim off, the manual says there are airbag-related clips I need to replace before reassembly. I have tried (gently) to remove the tweeter grilles (sort of rounded off triangles) and they don't seem easy to remove - didn't want to break anything.
And does anyone know how the OEM door speakers and tweeters are wired? Just wondering whether to remove the existing wiring or re-use it, is there a crossover somewhere? (I would need to replace it with the one from the new speakers if so).
Any and all input would be much appreciated!
Thanks
Paul
Paul Evans is offline   Reply With Quote
Old 04-23-2012, 03:31 AM   #2
Paul Evans
And in case anyone else wants to know, I have now answered my own question, via a circuit diagram from a "usually reliable source".
In a 2009 UK Yaris with the 6 speaker setup (2 front, 2 back and 2 tweeters) the front door speakers and the front tweeters on each side are wired in parallel. The wiring seems to go from the HU to the tweeters on each side and then down into the doors.
This means -
- that the tweeters at least must have a cap mounted on each tweeter to roll off the low frequencies
- that the front door speakers may have a choke mounted on the back to filter out the high frequencies (different part number to the normal 4 door speakers)
- that putting component speakers with crossovers into such a system is going to be tricky using the existing wiring!
Not rushing into action now, having a bit of a think!
Paul
Old 12-16-2024, 03:27 AM   #3
DRAGONHEAD_NZ
Drives: Toyota vitz (yaris)
Hi there, this might be a long shot as I know this post is quite old, but what was the outcome of this? I have a situation where I have the same set up, and the two tweeters are working fine but the front speakers in the front doors are not working anymore, doesn't sound as simple as just swapping the speakers for new ones if tweeters and door speaker are connected in parallel. Would love to know how it worked out for you!
DRAGONHEAD_NZ is offline   Reply With Quote
WTB: 2006-2008 Yaris Stereo Wiring Harnesses, AUX Jack zerosktz Willing to Buy by private party 4 02-19-2011 02:41 PM
2010 Toyota Yaris OEM Radio FPG Items for Sale by private party 2 07-05-2010 01:10 PM
