Old 04-02-2016, 05:36 PM   #1
Keymaster
Drives: Yaris '06 1300cc
Parking brake cable replacement
Hello guys! I was wondering if anyone has ever came across a service manual, for the European yaris with disk brakes on the back. I am trying to find something around but I am having a hard time with that.
I want to check out how much work does it need to replace the parking brake cable. It was rather difficult to take it out from the calipers that I am trying to replace, due to rust/dust etc and I was checking around how can I replace it.
Any thought or ideas are highly welcome.
Yaris 2006 - 2SZFE
Keymaster is offline   Reply With Quote
Old 04-02-2016, 10:13 PM   #2
tmontague
tmontague's Avatar
I changed mine on my rusted Echo and it's fairly strait forward. I didn't drop my exhaust as it was old and rusted , it was was pain to work around that. I recommend dropping the mid piper for better access.
Just disconnect I from the parking brake lever as well at the brake drum. Then remove the whole assembly. There are a few 10mm bolts holding the cable to the car. 2 of mine we do rusted the bolt heads sheared off and a bolt extractor wouldn't work as they were so badly seized. I just zip tied the cable to stay under the car and it worked fine.
Jack up the car and folow the cable from the drum to inside the car and inspect the bolts. It'll give you a better idea of what you're in for
Old 04-03-2016, 07:31 AM   #3
Keymaster
Cool, I was checking the service manual for the ones with the drum on rear and various videos on different cars (I cannot find something with Yaris) and it's more or less what you have described.
I ordered a new cable and when it comes I will proceed (be aware for a DIY ).
Yeah I guess that I will find some rusty bolts as well.
Old 07-12-2018, 10:41 AM   #4
Pinchlite
Drives: 2007 yaris HB
Did you get this job done?
Pinchlite is offline   Reply With Quote
Old 11-17-2024, 12:10 PM   #5
HDS
Drives: 07 Yaris, Saab 900 Turbo
How does one remove the parking brake cable from the drum? I have apart the drum, I cannot see a non destructive way to remove the cable. The cable is fine I just need to get it out of the drum so I can drop the axle.
HDS is offline   Reply With Quote
Old 11-18-2024, 11:23 AM   #6
thetut
Drives: 2007 4dr sedan
https://www.youtube.com/watch?v=qGeTOBWg3YE
thetut is offline   Reply With Quote
Old 11-24-2024, 03:12 PM   #7
HDS
That guy didn't even remove the cable
Old 11-24-2024, 07:51 PM   #8
thetut
Try this: https://www.youtube.com/watch?v=89PV3N3hIWs
Look from 9:01
The Basics on Brake Upgrades kngrsll Performance Modifications 56 03-06-2024 09:50 AM
Woops. Parking brake override vs. Rostra cruise control Kar98 In Car Entertainment + Electronics (audio / video / alarm) 5 01-13-2016 10:03 PM
How to access parking brake cable near front? xdarkxfirex DIY / Maintenance / Service 1 09-22-2015 03:58 PM
E Brake Cable tmontague DIY / Maintenance / Service 0 10-31-2014 11:01 AM
DIY For radios that require attaching a wire to parking brake Slick DIY / Maintenance / Service 0 04-16-2009 09:14 PM
