Old 02-09-2025, 12:54 PM   #1
naossoan
Drives: 07 Yaris 3DR
Hub Assembly or Wheel Speed Sensor?
Hi all,
in 2022, I had an ABS fault on my 2007 Yaris. I used a computer scanner which told me there was a fault with the rear wheel speed sensor, rendering the ABS system inactive.
I and ordered a rear wheel hub with built in ABS wheel speed sensor for around $50 CAD from Rock Auto. I took a gamble and replaced the rear-right wheel hub assembly, since the computer doesn't report WHICH ONE is faulty. Just that it is in the rear. Cleaned out the electrical connections with some cleaner and re-assembled.
This cleared the issue. Yay!
Well, now I have the ABS fault again. Looking on Rock Auto, I'm seeing the complete hub assemblies, but also a standalone wheel speed sensor part.
It's my understanding that the wheel hub and wheel speed sensor are a complete unit. That you can't detach the speed sensor itself and replace it.
Is that true? There's a basic listing of just the sensor here, as well as a wheel hub assembly that I have purchased in the past.
https://shorturl.at/Enjqz
For the whole hub assembly that I've purchased before
https://shorturl.at/U2znV
So my question is. Can I just buy the sensor and replace it? I was under the impression that I couldn't.
naossoan is offline   Reply With Quote
Vehicle Speed Sensor Problems jacl3 DIY / Maintenance / Service 1 06-23-2025 02:16 AM
2007 Yaris Speed sensor Harness 90980 11143 Ben_davis General Yaris / Vitz Discussion 4 04-01-2017 06:00 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 05:20 PM
2nz-fe speed sensor help trupial DIY / Maintenance / Service 2 06-11-2015 10:12 PM
Fix for Broken Speed Sensor Wire? BentSpace DIY / Maintenance / Service 13 06-02-2015 08:04 PM
