Down With the Sickness
oops is too much power bad
hey guys, i accidentally bought the wrong amp, i was looking for a 1000w mono amp and accidentally got a 1000w, 2 channel amp, its a ppi a1000. its rated at the following
# 1000 Watts max # 175 Watts x 2 @ 4 ohms # 250 Watts x 2 @ 2 ohms # 500 Watts x 1 @ 4 ohm # bridged (mono) load indepence in stereo:2-8 ohms # load indepence in bridged:4-8 ohms # Amplifier efficiency is 50% into 2 ohm load at max power. i was considering using it to power up a set of component speakers rated at 100w rms max 200w. so can i use this amp to power up the speakers at 4ohms and will it be fine or its too much power for the speakers to handle. or should i just look for 2 subs and use the amp to power it up.
Strength - Determination - Merciless - Forever |
![]() ![]() ![]() ![]() Drives: Sc'd Yaris Sedan. Join Date: May 2007
You can't give speakers too much power. They just won't use what they don't need. You can run the speakers off it if you want. It would be a huge waste though. I say run the subs. My 4 JL's are set to two 500/1's and I've never had a problem. So 1000/2 should be huge.
Tantum religio potuit suadere malorum. |
More power = more headroom. The ability to play with less distortion.
It's more likely to blow a speaker with a small amp run to distortion than with a large amp run clean. You can, on loud transients, have so much power that you push a voicecoil out of the magnet gap, but that is rare. Enjoy the headroom! |
sweet, i got it a low price so it should be a good, basically gonna run a 3 speaker setup, a pair of components and a sub, that should be good with optimum angles
![]() Drives: NA Join Date: Jun 2007
sell it and buy a couple of these, hurry tho, while supplies last
http://www.cadencestore.com/ProductC...idCategory=125 some of the amps are going for $129.. reg $489 heres the regular prices.. http://www.cadencestore.com/ProductC...?idCategory=99
Red Top, 9833, 180CS, 12" HC in 3.6@29, a1200 |
Never can have too much power.
| Questions and advice required about power upgrading(windows & locks) | W.A.S.P | DIY / Maintenance / Service | 10 | 07-22-2009 02:59 AM |
| Well seems the F&*king Power Package with Manual is impossible in the States(Hatch) | gaffo | General Yaris / Vitz Discussion | 28 | 07-15-2007 07:55 PM |
| convenience vs. power package | jeff_o | General Yaris / Vitz Discussion | 25 | 10-17-2006 10:04 AM |
| Need Help - Electrical (finding Power) | Ayka | DIY / Maintenance / Service | 7 | 10-12-2006 11:51 AM |
