Old 07-13-2007, 07:17 AM   #1
gwasabi
Drives: 07 Blazing Blue LB
Just got my COMPUSTAR
Just got my compustar alarm.
Any tips and hints I should know before I install?
gwasabi is offline   Reply With Quote
Old 07-13-2007, 09:42 AM   #2
Capagotks
Chode
Capagotks's Avatar
Drives: Silver 5 Door YRX 1.5L I4
Send a message via MSN to Capagotks
the most important thing is that the wiring is ALL BLACK. sure it makes it a pain in the ass to install, but can also deter/prevent a thief from stealing your car.
Make sure the control box is hidden well, and if its under the dash, put it up high.
Have a siren pointing down towards the ground under the dash (if thats where you put it) so it makes it difficult for the thief to go near the control box without hurting their hearing (but that can also help them find it, so put one under the seat)
last, wrap all the wires in electrical tape or some plastic tubing (or similar) to slow them down. it might also confuse them into thinking that it is stock wiring.
Capagotks is offline   Reply With Quote
Old 07-13-2007, 09:44 AM   #3
nqd
Drives: 07 Yaris LB Absolute RED
is it hard wiring up an alarm system?
nqd is offline   Reply With Quote
Old 07-13-2007, 09:53 AM   #4
Capagotks
Chode
Capagotks's Avatar
not if you have instructions.
usually (depending on what alarm you have) you need to wire the hood, tailgate, doors, door locks, the ignition, hazard lights, horn, shock/microwave motion sensor, etc. its not worth the hassle doing it yourself. if you get someone else to do it (pro) you'll probably get a warranty.
note for the black wiring: you can put little sticky tabs on the wires telling you what they are, just be sure, just make sure you take them off when your done ;)
Old 07-14-2007, 04:30 AM   #5
gwasabi
somethings wrong with my compustar. The Unlock works but the Lock doesn't work. Is it some kind of wiring issue?
Old 07-14-2007, 05:06 AM   #6
Capagotks
Chode
Capagotks's Avatar
i dont think so. if it was a wiring issue, it wouldn't unlock either. get it check it out or email the company
Old 07-14-2007, 06:00 AM   #7
gwasabi
it unlocks but it wont lock. when I have the unlock wire in the lock harness it locks. I think it might be a defective item
Alarm/Security Recommendations?? static808 In Car Entertainment + Electronics (audio / video / alarm) 7 09-12-2006 08:55 AM
