Old 03-15-2007, 01:56 PM   #1
IllusionX
Drives: 07 Yaris Sedan Aero
Spring rates
Anybody know the spring rates for the OEM springs? trying to look for something that will actually improve my handling, and not just make my ride harsher like my echo...
Old 03-15-2007, 03:45 PM   #2
forpinks
forpinks's Avatar
Drives: 03 Toyota Corolla S modded,
if you cut your stock springs you will have the same spring rate...
but, with lowering spring there should be about a 30% spring rate increase some are 15% for comfort... try Tanabe, they should have something called an NF210
and DF210... add upper front strut bars and upper rear bracing, it should cost you $160 for front and rear... change the shock and struts too with harder ones, and your ready for Auto-X buddy !
you might want to custom make some under-bracing with your welder buddies because they cost a leg because their from Japan ...
forpinks is offline   Reply With Quote
Old 03-16-2007, 12:25 PM   #3
IllusionX
hey, i'm asking for the oem spring rates... i'm not asking about what increase... :sigh:
as for my echo, i had the eibach pro kit's... and that did nothing to help handling.
Old 03-16-2007, 02:26 PM   #4
forpinks
forpinks's Avatar
dude! just go for the Tanabes! their from Japan! and give you a 30% spring rate increase from stock AKA harder springs for $200... If you want something that will really affect handling get some Tein Coil-overs with the spring rate and height controller...
ask Etimago about that...
BTW, Eibach suck when its cheap!
Old 03-16-2007, 09:05 PM   #5
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
trd is eibach?
(god this girl on my phne talks so much, i never tho gurls could but this annoying...I can think of several things to shut her up if she was here)
sht wont shut up!!!
-- Blen
Old 03-16-2007, 10:13 PM   #6
from what i hear, TRD are rebadged Eibach's.
Old 03-17-2007, 12:47 PM   #7
IllusionX
TRD sportivo's aren't as stiff as the eibach pro kit's i had. possibly still eibach but not the pro kit.
and no, i'm not going to choose a suspension setup without knowing what i already have.
say the oem spring rates are 300/150, and you get new ones that are 600/300, then it's going to be totally useless except making the ride harsher.
you see what i mean?
Old 03-20-2007, 03:32 PM   #8
IllusionX
i can't belive nobody has any info about this :(
Old 03-20-2007, 05:45 PM   #9
jdubau55
Drives: 2007 White Yaris LB 5 Spd.
Send a message via AIM to jdubau55 Send a message via Yahoo to jdubau55
Have you tried to contact Toyota? or an aftermarket spring company like Tein or Tanabe. I bet they could tell you in 5 minutes.
jdubau55 is offline   Reply With Quote
Old 03-21-2007, 10:30 AM   #10
IllusionX
i have hard time figuring out how to call "spring rates" in french lol. There's the problem :P
Old 07-22-2007, 04:05 PM   #11
dsc_pat
track or die
Drives: Yaris LB CE CDM
ttt
dsc_pat is offline   Reply With Quote
Toyotaland Spring Meet April 21, 2007 MtyMseHArmer Rocky Mountains / Great Plains 13 03-31-2018 03:31 AM
TANABE DF210 Spring Install [pics] Chris07LB DIY / Maintenance / Service 148 07-16-2007 10:26 PM
FS: CUSCO Compact S Coilovers (SoCal) 03Z33 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 6 02-14-2007 01:21 AM
17" Kobe, Spring Tech, TRD FlintS Wheels, Tires and Suspension Forum sponsored by The Tire Rack 19 09-24-2006 11:39 PM
Spring Install Price redglare45 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 1 06-30-2006 09:32 PM
