I want JDM bumpers!
Drives: 5 Dr Yaris RS in Blazing Blue Join Date: Feb 2006
[HELP] Keeping fog lights when installing HID
Just wondering, is there a way to keep the fog lights (on Canadian models) when changing to HID? I saw on the other thread that people are talking about "possible" ways, but has anyone tried and found a way that really works? Much appreciated. Thank you!
In addition, is it possible to make the fog lights or parking lights the DRL when changing to HID? Thank you! Last edited by GabL; 07-23-2007 at 12:58 PM. |
![]() ![]() ![]() Drives: 2005 Toyota MR2 Join Date: May 2006
Find a wire that goes live when the headlights are switched on. There MUST be a "headlights on" signal wire from the switch to the DRL box or wherever headlight voltage is controlled.
Tap this wire to run your relay. If this makes absolutely no sense to you (it depends on your knowledge of electronics) let me know |
I want JDM bumpers!
Has this been tested? Anyone? Thanks!
![]() ![]() Drives: 07 5 door Hatchback Join Date: Jul 2007
I want JDM bumpers!
I believe that DRLs must be mounted in the main headlight assembly. Foglamps are too low.
I want JDM bumpers!
#8 | |
Best check with your jurisdiction. DRLs are useless. If you can't see another car during the day, you shouldn't be driving. OTOH, there are way too many idiots that don't turn on their headlights when needed. I would prefer to see DRLs gone and replaced by a mandatory 'Auto' setting on the light stalk. With no 'Off' position. |
Switching to HIDs is illegal in the first place. That said, there is no way in hell I would stuff an HID bulb into the stock headlamp anyway. There is no option except a proper retrofit for me.
OEM daytime running lights that I've seen either use the headlights (rare, but the Yaris is an example), highbeams (almost all other cars), or parking/signal lamps (many new GMs IE new corvette). I have never seen foglight based DRLs, as they are probably far less effective at acting as DRLs. I find that yellow DRLs are more noticeable, yet less blinding than half-powered high beams, and this is the route I intend to go when I do my retro. |
#10 | |
I want JDM bumpers!
toyota
actually i beg to differ.. drl does help alot on rainy days, foggy days specially in canada we do get them weather .. specially fog on daytime is a killer. but that depends on where you are ofcourse... and that other people having it not you as the driver..you having drl help other people to see you on this crazy road conditions.
Yeah but if peeps turn on their headlights when they should, there would be no need for DRL. I would much rather see stalks where the only 2 options are auto and on. That would also prevents those f'ing idiots who drive with no lights at night because there are street lights.
toyota
well were not talkin about night time driving, Its daytime fog and rain condition (daytime running lights) people dont turn their headlight on on day time no use and no effect because we human first act on things we do based on our own benefits turning headlights on on day time benefits other people but not the driver itself.. just im own personal comment im sure others got it differently...
toyota
but the way 2 ways to keep drl with hid. 1. relay. 2. transfusion.
#15 | |
FYI, I'm going to write this post as if you know very little about electronics (just for the other readers out there). Let's start with the headlight circuit diagram from the repair manual. Don't kill me guys... It's a huge picture. I connected all 3 pages into 1 image to make it easier to trace the wires: ![]() Our headlights are dual filament bulbs (with separate filaments for high and low beams). There are 3 connectors on the bulbs: One pin connects to the high beam, one connects to low beam, and one is connected to BOTH (it is a common pin). To make it easier for now, let's look at only the headlight bulb on the very left side of the diagram (which is actually the right-side bulb on the car). You'll notice both filaments are connected directly to the battery by the black wire, which is our common wire. So the headlight switches and DRLs and such are on the ground side of the bulb. The green wire is the ground for the high beam, and you can ignore it for now (we will discuss high beams later). The blue wire is for the low beam. The blue wire splits off. One side goes to the DRL box (which I assume provides a weaker ground, meaning less electricity). The other side goes around through the switches/etc and eventually goes to the ground. ... I will finish this post later. Need to go to sleep right now. Sorry =p |
I want JDM bumpers!
Hey! This is exactly what I needed! But this diagram seems a bit complicated... haha!
The reason I am asking is because I got the OEM HID Module from oversea, and I would like to know how can I hook it up to make it works on our NA models. The HID Module has four bulbs in it, I still have to figure out which one is which. This is what I think they are: One HID Buld for low beam, one regular buld for high beam, one parking light and one signal light. I will do a check with the multimeter to see which wire goes where later. But GuySmiley, it will be appreaciated if you can continue with your post. Thank you! |
Information on HID Bulbs
HID bulbs are... sensitive... compared to regular halogen bulbs. They require extra voltage to start up (ignite), and if you turn them off, you must let them "cool down" before turning them back on (30 seconds or so). This is because of the materials used in HID technology. When you first turn HID lights on, extra voltage is applied to the bulbs (20,000-25,000 volts I think) to convert salts in the bulbs into xenon gas. This is why when you first turn on your HIDs you will see them change colors, starting blue or green, then eventually becoming pure white (or whatever color your bulbs are). The ballasts (the boxes that power HID bulbs) slowly turn down the power to the bulb, since it takes less electricity to keep the lights on once the startup/warmup process is complete. When you turn the lights off, the voltage to the bulbs are cut off, and as the bulbs cool down the xenon gas slowly turns back into solid salts (takes about 30 seconds). Now... If you flick your HIDs off and on, they will get pissed off at you and turn red/orange/pink. No joke. When you turn the lights back on, the ballasts feed the full 20,000+ volts into the bulbs even though the salt has already been converted into xenon gas. This damages the bulbs and significantly decreases their life span. Why does this matter to you? With your stock headlights, when you flash someone (or switch to high beams), your low beam turns off, and your high beam turns on. Duh, right? But what if we switch to HIDs? Now we've got a problem. We need to keep the low beam on AT THE SAME TIME that the high beam is on. Don't worry, we can solve this very easily when we begin wiring the HIDs. Information on Wiring Harnesses Some people will tell you that you can power your HIDs off of the stock wiring 100% safely, and that they have been doing it for the last 10 years!!! Sounds great, right? There are several reasons I refuse to take power from the stock headlight wires:
What really happens most of the time is people try to use the stock wires for power, but find the HIDs only go "click click click click" and flicker on off on off (which is bad for the bulb as I have already explained). This is because the HID ballast starts to ignite the bulb, but runs out of juice due to the restrictive stock wiring. It tries this over and over again, which slowly kills both itself and the bulb. Some people don't have this problem, but to me, it just isn't worth the risk of losing my whole car. The Solution If we use the stock headlight wires to trigger a relay (a special type of switch), we can avoid all these problems. The relay will connect the HID ballasts/bulbs to the battery/ground, using our own wires chosen for this specific purpose. I'll add more background info as we need it. Now that we know what to do, let's get started. (I'm working on post/part 3 now) ----------------------------------- fyi, the foglight bulbs appear to be positive switched, while the relay that switches the foglights are negative switched. Confused yet? lol.. Unfortunately, I think the fog lamps turn off when the high beams are turned on, so you cannot simply wire the + and - wires of the fog lights to trigger your relay. The solution is similar to how we will wire GabL's low beam. Last edited by GuySmily; 08-01-2007 at 08:29 PM. |
toyota
wicked diagram gabl..question though.. so the headlight is turned on thru ground not power + wire? what about the fog light how was that turned on?
| Fog lights and shift knobs | flip_yaris | Cosmetic Modifications (Exterior/Interior) | 3 | 10-20-2008 05:36 AM |
| Disabled DRLs and Factory fog lights | DARKYARIS | DIY / Maintenance / Service | 21 | 05-01-2007 05:32 PM |
| Fog lights and shift knobs | flip_yaris | Cosmetic Modifications (Exterior/Interior) | 4 | 09-26-2006 10:48 AM |
| can i / where to get factory switch for aftermarket fog lights? and exhaust tip q. | fantabulousbaby | Cosmetic Modifications (Exterior/Interior) | 22 | 08-29-2006 01:13 PM |
| Fog lights for S sedans (US version) | paeko73 | General Yaris / Vitz Discussion | 11 | 07-02-2006 11:38 PM |
