Old 04-17-2007, 12:07 AM   #1
5spBlazer
Cybernetic Magician
5spBlazer's Avatar
Installed Tach...Tach works, RADIO doesn't!
Well I installed the tachometer today. Its a small 2" sunpro.
Tach works well, but now my radio doesn't work. I followed the DIY on the site for the tach install, but hark, but radio is gone! What could i have done to kill the radio?
5spBlazer is offline   Reply With Quote
Old 04-17-2007, 12:15 AM   #2
PetersRedYaris
PetersRedYaris's Avatar
Drives: 2005 Scion xB
Numero uno, check the fuse as you may have blown it during the wiring.
PetersRedYaris is offline   Reply With Quote
Old 04-17-2007, 12:15 AM   #3
Blenjar
Blenjar's Avatar
Drives: Black Yaris 07 HB
check the fuse.
-- Blen
Old 04-17-2007, 12:17 AM   #4
uncleyaris
off topic , but Blen that radio was not meant to be dude!
Old 04-17-2007, 12:17 AM   #5
5spBlazer
Cybernetic Magician
5spBlazer's Avatar
Which fuse goes for the radio?
Old 04-17-2007, 12:22 AM   #6
PetersRedYaris
Look in the owners manual. There should be a diagram of each fuse box on the car and labels for which fuses controls what.
Old 04-17-2007, 12:45 AM   #7
5spBlazer
Cybernetic Magician
5spBlazer's Avatar
Well, i placed a new fuse for the radio and the radio still doesn't work. I figured that the radio might work if i placed the the originel fuse in the place where i installed the red wire, but that doesn't work either. I can't figure out why the radio might not work.
I had foglights installed at a sound shop. When i was installing the tach there were alot of extra wires in there for the fogs. Could they have something to do with this.
I've basically narrowed it do to either the red wire or the white one. Can't be black cause thats ground and nothing to do with audio? and green since its just going to the engine....
I'm confused.
Old 04-17-2007, 01:17 AM   #8
Nutzoids
Nutzoids's Avatar
Drives: 07 Yaris Liftback
I'm confused.
Alright...
Black = "HotWire" Current Flowing
Green = "Ground" Drain Voltage
Red or White = "Neutral" or "+"
*Philosophy of life... Brought to you by... "Nutzoids"
Nutzoids... Where Punk rock is less about Image, and more about the Mind!
Nutzoids is offline   Reply With Quote
Old 04-17-2007, 12:48 AM   #9
yrsdrgn
yrsdrgn's Avatar
Drives: 2007 Yaris
I'm pretty sure this is a bit off topic but do you mind posting pictures of where you put your tach? I'm just looking at the location of where people who have done the install put their tach before I install mine.
Thanks
Old 04-17-2007, 12:49 AM   #10
5spBlazer
Cybernetic Magician
5spBlazer's Avatar
Thanks
....Sure just give me one second
Old 04-17-2007, 01:02 AM   #11
spkrman
Drives: 1
something has to be disconected on the radio end.
Go over all wiring, and make sure the harness is plugged into the radio.
Troubleshooting should be straightforward.
Old 08-04-2007, 04:07 PM   #12
kapo
Argentina Presente!
Drives: 07 White LB
im having the same problem.. any solution?
kapo is offline   Reply With Quote
Old 08-05-2007, 09:42 PM   #13
cdmyaris
cdmyaris's Avatar
wait, is your radio/cd player still working? Cause, im running a problem with my tachometer it works but my cd/radio player light isnt working but still plays.
cdmyaris is offline   Reply With Quote
Old 08-06-2007, 01:28 AM   #14
5spBlazer
Cybernetic Magician
5spBlazer's Avatar
My Cd/radio still work. I decided to splice the tach into my foglight instead of running it into the fuse box directly.
Old 08-06-2007, 02:12 AM   #15
cdmyaris
cdmyaris's Avatar
oh, then does it works now? give us updates.
Old 08-06-2007, 12:35 PM   #16
5spBlazer
Cybernetic Magician
5spBlazer's Avatar
yea, everything works now.
Old 08-06-2007, 12:58 PM   #17
kapo
Argentina Presente!
Drives: 07 White LB
I have the blue inside light from the dealer, so maybe I will power the tach from there...
Old 08-06-2007, 09:57 PM   #18
IllusionX
Drives: 07 Yaris Sedan Aero
Hmm... the yaris has a switched negative!!! so any battery positive is constant everywhere in the car.
my guess is make sure you don't switch the wrong wire :)
Anyone installed a tach mrrock Performance Modifications 1 10-19-2006 10:57 PM
