Old 11-19-2008, 11:20 PM   #1
SweetRS
Drives: 2006 Yaris Rs
amp/sub cutting out need help!!
i have a jvc kd g430 and a 4-channel 300.1 phoenix gold amp for a 12" kicker, i have everything wire properly - ithink - and it sounds good right til the point where the amp turns off frequently, i dont understand this problem, can some one please tell me what to do? do i need a cap???
SweetRS is offline   Reply With Quote
Old 11-19-2008, 11:29 PM   #2
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
might be over loading.. the ohm load right?
Old 11-19-2008, 11:58 PM   #3
staypuft
aka SDMF
staypuft's Avatar
Drives: 07 LB Met Met
maybe amp getting 2 hot? or your wires are reversed
staypuft is offline   Reply With Quote
Old 11-20-2008, 12:34 AM   #4
sportin83
Drives: 2008 blazing blue yaris LB
how are the speaker wires wired from the sub to amp? bridged or stereo, is the sub dual voice coil? 2 ohm or 4 ohm?
http://cardomain.com/ride/3151056
mods: custom sub box, i hit 141.4 db, new speakers, double-din nav, foglights, cruise, CAI, strut brace, under car braces, short antenna, remote start, alarm, actuators in doors and hatch
coming soon: window tint, custom sub grills, tach and........
sportin83 is offline   Reply With Quote
Old 11-20-2008, 09:06 AM   #5
SweetRS
im pretty sure its bridged. its not dual voice coil, and i dont remember which ohm it would be. ill have to take a look at it... could that be my problem? that im overloading it? sometimes the sub with have a minor popping sound too.
Old 11-20-2008, 09:24 AM   #6
IllusionX
Drives: 07 Yaris Sedan Aero
phoenix gold 300.1 is a 4 channel amp ?
Old 11-20-2008, 09:47 AM   #7
SweetRS
[QUOTE=IllusionX;179183]phoenix gold 300.1 is a 4 channel amp ?[/QU
sorry it says on the amp Q X 300.4
Old 11-20-2008, 10:04 AM   #8
SweetRS
and this is the sub, its a kicker f12a (thats whats it says on the sub itself)
Old 11-20-2008, 10:10 AM   #9
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
http://incolor.inebraska.com/weisina.../pg-qx3004.htm
Old 11-20-2008, 10:11 AM   #10
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
its not made to run mono... that might be the reason
edit.. maybe it is. weird they dont put the rating for the mono in the specs
Old 11-20-2008, 10:32 AM   #11
SweetRS
yeah i might change the amp anyway, the sub is 4 ohms and im only using 1 out of the 4 channels. and it says that if its only 2 channel than its will be 2 ohms, im not a genius and i dont really know what that means or whether its a bad thing....what do u think??
there are three rca plugins on the amp. front, rear, and output. my rcas and plugged into the "front" plug in, although its plugged into the "rear" rca plugin on the deck, i get bass from the sub, just im tired of it turning itself on and off numerous amount of times when i drive. There is a switch on the amp so that u can switch from front only input or front and rear together input" , i have it on front only.
Old 11-20-2008, 10:43 AM   #12
TinyGiant
Tiny Giant Clothing
TinyGiant's Avatar
i would think that would be the problem
http://www.marktaw.com/recording/Ele...dSpeakers.html
Old 11-20-2008, 11:02 AM   #13
SweetRS
so do you think that this would be a better bet??
MTX 1-Channel Car Amplifier (TC3001)
Old 11-22-2008, 08:55 PM   #14
sportin83
that mtx amp should work fine, but if sub is a single 4 ohm you would be best off with a 2 channel amp.
Cutting bumpstops on Tein springs... Smokey159 Wheels, Tires and Suspension Forum sponsored by The Tire Rack 15 10-30-2008 12:27 PM
FS: Custom Amp/Sub box for liftback!!!!!!! ism3t Items for Sale by private party 5 09-25-2007 06:23 AM
Yaris 06 H/B Engine Cutting out problem.. Farenheit General Yaris / Vitz Discussion 3 09-14-2007 01:21 PM
